LM1875 PCB, Which To Use - Page 16 - diyAudio
Old 22nd December 2008, 07:56 PM   #151
danielwritesbac's Avatar
Originally posted by pacificblue
Which is as true the other way round. 2 x LM1875 means per deinition 40 unprotected Watts. 1 x 3875 means 56 protected Watts, with the same component count as 1 x LM1875. Output power is similar enough to forget about it, price will be similar, complexity will be higher for 2 x LM1875. The only logical reason left to use 2 x LM1875 instead of 1 x LM3875 is to use it as a learning exercise.
Yes, of course a parallel LM3875 is worthy of exploration as well.
Old 22nd December 2008, 08:04 PM   #152
Originally posted by gekkehenk
I've changed several things
The inducter changed to 5uH as the documentation says it should be.
The coupling cap is changed to 220nF polypropyleen 5%. Also following the documentation. Al other caps are polypropyleen 1%.
Most application guides that contain a speaker output zobel and specify the cap, also specify mylar/polyester/MKT.
These are available with either the appearance of a "box" or as a "dip cap" (looks like bubble) cap. It is the polyester film dip cap that is most specific for speaker output zobel.
Old 23rd December 2008, 08:19 AM   #153
Send a message via ICQ to Kuzmenko
Pay attention that there must be space for screwdriver between powercaps...
Old 24th December 2008, 06:49 AM   #154
Screwdrivers! Oh what an adventure that was.
First, solder a cap, then. . .
2 oz vodka
5 oz orange juice
Next, solder the other cap, then. . .
2 oz vodka
5 oz orange juice
Wow, pretty soon, I had some sort of artsy sculpture sort of power circuit with eighteen caps. This wasn't my best idea.
Old 24th December 2008, 08:20 AM   #155
2 oz vodka
5 oz orange juice
2 oz vodka
5 oz orange juice
Finally the secret behind many of your posts is revealed.
Merry Christmas
David
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 24th December 2008, 08:44 AM   #156
Merry Christmas
David
Merry Christmas to you too!
I finally found that thing! It actually has 20 caps (four are snubcaps). Without further delay, here's the not-recommended, too many screwdrivers = too many caps power supply:
Old 24th December 2008, 06:23 PM   #157
I,m a big step futher with my pcb design now!!
I've build a variable regulated power supply with a LM317 and LM337.
4x 2200uF Nichicon PS series caps. Low esr and impedance.
2x 1000uF Nichicon PS series caps. Low esr and impedance.
Vishay 1837 series 100nF 1% MKP filtering caps.
The output coupling cap is an 220nF 5% Polyester.
At the input is a 2,2uF evox-rifa polyester coupling cap 5%
All resistors are 1% metal films.
The diodes are the Mur-860.
The layout is made by the document of the LM1875.
-The whole print is "euro" sized zo it will fit easy in many housings from 5cm or higher.
- Input and output is as far away as possible from the power supply rails for minimal distortion.
- The ground for the input and output is not connected with the ground from the power supply.
- The ground wire from the transformer is in center point of the rails between the big caps and the voltage regulators.
- Power supply is futher off the Lm1875 for minimal distortion.
The only problem are the voltage regulaters. I didn't know that they could not deliver 1,5 amps at high voltages....oops. So i'm going to use a buffer transistor for both sides?
I,ve looked for other 3amps voltage regulaters, positive and negative but i couldn't vind any pairs. The only one i could find as best match was the LT1083 with the LT350 form Linear.
Does anyone know a better combination with minimal components?
Waiting for comments
Thanx!
Old 24th December 2008, 06:23 PM   #158
Oh, i almost forgot!
Merry cristmas everybody!
Old 25th December 2008, 10:53 PM   #159
zikinho is offline zikinho  Croatia
Any experience with the PSU voltage regarding the sound? With what kind of rail voltage did you get the best sound?
P.S. Merry Christmas everyone.
Embrace the sound
Old 26th December 2008, 03:49 AM   #160
No, I haven't built it yet so I really don't know. I was planning to use a rail voltage from 28 to 30 volts.
Greetings
LM1875...how low can you go? Gcollier Chip Amps 7 6th May 2010 04:43 AM
How hot does an LM1875 get? Dominique Chip Amps 15 23rd January 2007 03:13 AM
lm1875 siemensc65 Chip Amps 4 23rd May 2006 04:28 AM
Lm1875 soundNERD Chip Amps 14 12th October 2003 03:26 AM
Copyright 1999-2017 diyAudio
