LM1875 PCB, Which To Use - Page 12 - diyAudio
Old 8th December 2008, 12:22 PM   #111
sneih is offline sneih  Indonesia
sneih's Avatar
ok bro, i will update as soon as possible.
btw can i replace 220uF with any bigger caps?
for the better sounds?
thx
Old 8th December 2008, 02:03 PM   #112
sneih's Avatar
double
Old 8th December 2008, 02:10 PM   #113
Khron is offline Khron  Finland
Send a message via AIM to Khron Send a message via MSN to Khron Send a message via Yahoo to Khron
This might be a bit more neat
Old 8th December 2008, 04:26 PM   #114
sneih's Avatar
hmm nice n simple layout than i make before....
imho, can you move 220uf n resistor behind lm 1875 more into for easily attached big heatsink? i have a same problem with pcb i make before!!
Old 8th December 2008, 04:41 PM   #115
Something like this, i guess. But then you'd have to mount the 22k resistor on the bottom of the board
Old 8th December 2008, 08:02 PM   #116
sneih's Avatar
hmm good alternatif
Old 8th December 2008, 09:37 PM   #117
danielwritesbac's Avatar
thx
But, this isn't what I was talking about.
Actually, I was talking about the place to ground the speaker.
The speaker ground is actually "speaker return" because almost all of the force that's sent to the speaker does come back into the amplifier, and we don't want that accidentally getting into either of the amplifier's inputs--so don't put speaker return ("out -") on the amplifier board.
You also get better bass if you provide the strongest possible reference to support the speaker's signal, and the strongest reference is the 0v (ground) output terminal of the power supply board. See also "Power Star Ground"
Old 9th December 2008, 12:56 AM   #118
thx
The optimal size will depend on which chip is in use, and many other factors, as well.
Good options include 220uF or 470uF.
Use whatever sounds clearest and use whatever power circuit doesn't promote ringing bass.
Pin compatible chips include:
National Semiconductor LM1875 > Use LM1875.pdf
or
SGS Thompson, ST, TDA2050 > Use TDA2050.pdf
Clone LM1875* > Use TDA2050.pdf
*The clone LM1875 does not differ from the clone TDA2050 except for the label.
Recently, I got the embarassing opportunity to learn more about this issue.
No speaker was harmed, but it was a near-miss. I thought it was a wonderful sale price; however, what I received wasn't what I had intended to purchase. There was more power and more bass, all of inferior quality.
Solution:
Whenever power output per voltage used is out of spec for LM1875.pdf, then use this (TDA2050.pdf):
http://www.datasheetcatalog.org/data...onics/1461.pdf
1). Don't exceed 26.7vdc rails (abs max for clone chip), and please consider using lesser voltage.
2). The optimal components for use at the amplifier board may be different when the chip is a different model.
3). And, keep the "NFB cap" (don't omit), because speaker safety is a primary concern for the less-durable chips.
Old 9th December 2008, 07:25 AM   #119
sneih's Avatar
i just update new layout, maybe like this?
Old 9th December 2008, 08:09 AM   #120
Maybe some problem attaching a heatsink?
LM1875...how low can you go? Gcollier Chip Amps 7 6th May 2010 03:43 AM
How hot does an LM1875 get? Dominique Chip Amps 15 23rd January 2007 02:13 AM
lm1875 siemensc65 Chip Amps 4 23rd May 2006 03:28 AM
Lm1875 soundNERD Chip Amps 14 12th October 2003 02:26 AM
Copyright 1999-2017 diyAudio
