LM1875 PCB, Which To Use
Old 6th February 2018, 09:01 PM   #281
Mark Whitney is online now Mark Whitney  Netherlands
Mark Whitney's Avatar
Originally Posted by ceneto View Post
is there a way to change some of the resistors and to keep the polyester capacitors (or increase them to 4uf - this is possible to fit)
is there online tool where I can check such calculations?
To get any real difference without changing the resistors, you can increase C5/6 to 100uF-220uF. If it will fit, you can use Nichicon Muse UES1E101MPM. What is not clear to me is how high the offset is or how high it will be after replacing the capacitors.
As a test you could short C5/6. Check DC (offset) at the output before connecting speakers. It should not be more than 50mV. This will get the FR under 10Hz.
Regards Mark.
Old 7th February 2018, 09:06 AM   #282
thank you for the answers
one more last question
is it good idea to use to electrolitic capacitors to make non polar one
in order to not have difficulties with the capacitor polarity
Using a pair of back to back polar electrolytics to make a Bi-Polar electrolytic works quite well.
The pair passes AC very well and even works for the much more onerous duty of filtering.
For DC blocking duty where you are not filtering the frequencies in the passband, an electrolytic is almost as good as any capacitor type.
Bi-Polars can also be used back to back and tests have shown this to give slightly improved performance in filtering duty, making them almost as good as MKT types.
regards Andrew T.
LM1875 PCB, Which To UseHide this!Advertise here!
LM1875...how low can you go? Gcollier Chip Amps 7 6th May 2010 04:43 AM
How hot does an LM1875 get? Dominique Chip Amps 15 23rd January 2007 03:13 AM
lm1875 siemensc65 Chip Amps 4 23rd May 2006 04:28 AM
Lm1875 soundNERD Chip Amps 14 12th October 2003 03:26 AM
