LM1875 PCB, Which To Use
Old 27th December 2008, 09:04 AM   #171
zikinho is offline zikinho  Croatia
I have another tranny 150VA, 2x20VAC. Thanks for the answers.
Embrace the sound
Old 27th December 2008, 09:08 AM   #172
danielwritesbac is offline danielwritesbac  United States
danielwritesbac's Avatar
20vac x 1.43 = 28.6vdc rails. This is nice for 16 ohm speakers.
Edit: But this voltage is so high that its not documented for use with LM1875. Please choose lower voltage.
Old 27th December 2008, 09:54 AM   #173
pacificblue is offline pacificblue  Germany
You can use up to 30 V with 8 Ohm speakers and up to 25 V with 4 Ohm speakers. The latter could run into heatsinking limits.
If you have the 200 VA 2x18 V transformer lying around, use it. The voltage is okay and the power,...
well, you will have lots of headroom even with a two-channel amplifier.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 27th December 2008, 10:02 AM   #174
There's a problem with the thermal junction, along with a few things I didn't want to mention because there could be electroshock or full-rail DC offset from a damaged chip because of what happens when it has expired.
Okay, so I gave conservative figures and you caught me.
Any moment, I expect AndrewT to come along and tell me that my conservative figures are too high.
What can be done?
Maybe this:
File Type: jpg circuit-power-amp-super-bridge-120w-by-ic-tda2030.jpg (90.0 KB, 1054 views)
Old 27th December 2008, 10:22 AM   #175
I allready made this one using LM3886, and also one small amp using LM3875. Wanted to try LM1875 just to compare to the other two.
Embrace the sound
Old 27th December 2008, 10:41 AM   #176
@PacificBlue Look at that! There's an exposed heatsink and a ground reference within 1 cm of each other. My voltage figures were correct. I gave the voltage figures assuming an insulator pad will be used with LM1875 for safety.
@zikinho Its not difficult to create a parallel LM1875 amplifier. That can use your 18vac+18vac transformer along with either 4 ohm or 8 ohm speakers.
Old 27th December 2008, 10:45 AM   #177
Is this a center tap (3 wire output) or is it a dual secondaries (4 wire output)? I ask, because it is possible to create a very inefficient rectifier for a dual secondaries transformer. Some purposeful inefficiency at the rectifier will drop the rail voltage. This is just slightly complex to do, and there's no need to discuss all that bother if that is a center tap transformer for which the technique wouldn't make a sufficient voltage drop.
Old 27th December 2008, 10:46 AM   #178
Inside...
Embrace the sound
Old 27th December 2008, 11:04 AM   #179
It is a center tap. Both of them are.
Embrace the sound
Old 27th December 2008, 01:02 PM   #180
Well, the 18+18vac transformer can be used with a parallel LM1875 amplifier on either 4 ohm or 8 ohm speakers. Its a pretty good option because it solves a difficult problem with LM1875's current handling capacity.
When used in parallel, it spots half the load (it sees your 4 ohm speakers as 8 ohm speakers).
LM1875 PCB, Which To UseHide this!Advertise here!
LM1875...how low can you go? Gcollier Chip Amps 7 6th May 2010 04:43 AM
How hot does an LM1875 get? Dominique Chip Amps 15 23rd January 2007 03:13 AM
lm1875 siemensc65 Chip Amps 4 23rd May 2006 04:28 AM
Lm1875 soundNERD Chip Amps 14 12th October 2003 03:26 AM
