LM1875 PCB, Which To Use
Old 26th December 2008, 05:29 AM   #161
danielwritesbac is offline danielwritesbac  United States
danielwritesbac's Avatar
27
(or lower)
Old 26th December 2008, 07:46 AM   #162
R.I.P.
Originally posted by zikinho
Any experience with the PSU voltage regarding the sound? With what kind of rail voltage did you get the best sound?
you must follow the recommendations for maximum rail voltage as spelled out by National.
This depends very much on the load impedance and the heatsink dissipation ability.
You can use a lower voltage but I do not recommend you adopt a higher voltage.
Generally, supply <=+-40Vdc for 8ohms, <=+-30Vdc for 4ohms.
regards Andrew T.
Old 26th December 2008, 07:25 PM   #163
zikinho is offline zikinho  Croatia
Thanks, been thinking about 200VA, 2x18 ct tranny.
Embrace the sound
Old 26th December 2008, 10:04 PM   #164
pacificblue is offline pacificblue  Germany
How many LM1875s are you going to drive with 200 VA?
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 26th December 2008, 11:09 PM   #165
Only two of them. Tought it wolud be enough.
Embrace the sound
Old 27th December 2008, 04:13 AM   #166
18 + 18 = 36
There are 5.56a of 36v in 200va.
You have 5.56 ampers there.
This is like: "That's kind of big, and you're planning to put it WHERE?"
The transformer is slightly oversize on amperage, possibly resulting in additional bass or a bit less mids at end result.
I would predict possible results at any point between fantastic or overdone.
Old 27th December 2008, 07:14 AM   #167
I'll try it. I've had that one lying around for quite some time, and there is no extra cost.
Embrace the sound
Old 27th December 2008, 07:17 AM   #168
Theoretically, at that voltage, it is suited to 8 ohm speakers.
Old 27th December 2008, 07:39 AM   #169
Ok. What rail voltage would i need to drive 4 Ohm speakers?
Embrace the sound
Old 27th December 2008, 07:57 AM   #170
To answer that particular question, I'd have to say 21vdc rails (or less).
Optionally, you can use the transformer you already own along with a parallel LM1875 amplifier (two chips per each channel). That will work on either 4 ohm or 8 ohm speakers.
LM1875 PCB, Which To UseHide this!Advertise here!
LM1875...how low can you go? Gcollier Chip Amps 7 6th May 2010 03:43 AM
How hot does an LM1875 get? Dominique Chip Amps 15 23rd January 2007 02:13 AM
lm1875 siemensc65 Chip Amps 4 23rd May 2006 03:28 AM
Lm1875 soundNERD Chip Amps 14 12th October 2003 02:26 AM
