LM1875 PCB, Which To Use
Old 13th December 2008, 04:52 AM   #141
sneih is offline sneih  Indonesia
sneih's Avatar
good layout my friend: ortega!!
some opinion that i heard about disadvantage of using fuse after rectifier /board is can damage your expensive speaker if only 1 of 2 fuse death...
maybe someone can explain how it do that?
cmiiw
Old 13th December 2008, 08:01 AM   #142
pacificblue is offline pacificblue  Germany
The first amplification stages in the IC are usually referenced rail-to-rail. If one rail is missing their output is biased to the remaining rail and pulls the following stages towards that voltage. The result depends on which rail is missing and is either DC at the output (may blow speakers) or a blown IC, which usually means DC at the output afterwards (again blowing speakers).
With two rectifier bridges (one per rail) you can run into the same issue with fuses before the rectifiers. Use either a correctly dimensioned fuse before the transformer or a detection circuit that reacts to a missing rail by switching the other one off as well.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 14th December 2008, 04:56 AM   #143
danielwritesbac is offline danielwritesbac  United States
danielwritesbac's Avatar
Thanks PacificBlue!!
I think that two potentially recommendable spots for fuses is:
In series with the mains power switch to the amplifier
In series with the output + of the amplifier (3a fast blo?)
Probably convenient to install these in insulated fuse holders, to the amplifier enclosure, and so they're accessible.
What do you think of it?
Old 14th December 2008, 08:27 AM   #144
From the protective point of view fuses at the amplifier outlet are a cheap and efficient protection for amplifier and speaker alike.
Some people are convinced to hear a difference in sonic performance, when they swap automatic circuit breakers for gold- or silver-plated pure-copper-melting-wire fuses in their home's distribution box. Imagine, how they would suffer with a fuse added between amplifier and speaker.
Which arises an interesting question. Do audiophile melting fuses need burn-in?
Remember there are additional contact points with all their negative side effects, like contact impedance, parasitic capacity and inductivity. Fuse holders are often made from cheap spring-steel, which is magnetic, and the fuse is also a conductor with unwanted side-effects and must therefore have a "sound". For audiophilists these are all arguments against fuses in the signal path.
I once had a pair of speakers with melting fuses to protect the tweeters. I still have some with PTCs for tweeter protection. No significant sonic degradation for me, but then everybody percieves such effects differently.
Old 22nd December 2008, 12:38 AM   #145
gekkehenk is offline gekkehenk  Netherlands
Hi Folks,
I'm very new on this forum, yes it's my first post!
Following this topic for quite a while now.
I'm working on a LM1875 board to and i see that there are quite a few modifications to do as i read this topic.
My first pcb of the Lm1875 mono power amp.
Comments are welcome!
But i want to use two LM1875 parallel per channel. but is that as simple as the word says it is or do i have to change a lot of things?
And how about bridging the chip? The only thing i know that it can't run under 8 ohms load then.
Thanx
Old 22nd December 2008, 07:42 AM   #146
Its a very interesting board. Kudos!
Your speaker output zobel (RC) is too strong of a load. Use 8R in order to ensure compatibility with parallel operation. See National Semiconductor's AN1192.pdf for more information about parallel amplifiers.
And, LM1875's inbuilt limiter will reduce current handling to half power when bridged unless supplemented with added output transistors. I'd love to see this in action!
The TDA2050 is pin compatible and will bridge. Use lower voltage.
Old 22nd December 2008, 08:45 AM   #147
Wherever Daniel got the idea about the Zobel, it is usually good to stick with the datasheet recommendations, which is 1 Ohm and 220 nF. And use only one Zobel for a parallel application.
LM1875 can be bridged and paralleled. The current will not be halved. It is 4 A peak, the same as in TDA2040. TDA2050 has 5 A peak.
An easier and more logical way to achieve more output power is to select a different IC. Instead of bridging or paralleling LM1875, buy LM3875. Keeps component count low, layout simple and the price will not be much different either.
Old 22nd December 2008, 11:28 AM   #148
I should have said that bridged will not increase the potential for power output with 8 ohm speakers. See, that's a nice bland statement.
Zobel? 1R may be a wasteful amount of added load for an amplifier with limited resources, and does not represent a well done RC unless that cap is a 100v (or less) polyester/mylar type typically having 7+ ESR during the audio band. The type wasn't specified and its better not to guess.
There is a minor difference between LM1875 and LM3875 output power at end result (the speaker). It is less than 3db. LM3875 has the spike system that further limits output, plus LM3875 distortion increases with frequency, and so useful power output differences can be slim.
Old 22nd December 2008, 06:10 PM   #149
Thanx for the reactions!
I've read the application hints form the technical documentation of the Lm1875 once again.
I've changed several things
The inducter changed to 5uH as the documentation says it should be.
The coupling cap is changed to 220nF polypropyleen 5%. Also following the documentation. Al other caps are polypropyleen 1%.
The input of the pcb is going to be replaced futher to the left. The ducumentation says you otherwise get distortions beqause of the currents from the power supply. Also the speaker output with components is going to be replaced a little bit to the right.
Since i don't care about the size of the pcb I can change everything with hopfully the best results.
maybe a copper plate at c angle on the pcb grounded between supply and input section?
Power supply cables should be twisted I thougt it only has to be done with AC wires and not with DC wires.
Wow the chip can reach 170 degrees before thermal shutdown.
Time to draw a new pcb with a parralel or bridge mode.
Old 22nd December 2008, 07:52 PM   #150
Which is as true the other way round. 2 x LM1875 means per deinition 40 unprotected Watts. 1 x 3875 means 56 protected Watts, with the same component count as 1 x LM1875. Output power is similar enough to forget about it, price will be similar, complexity will be higher for 2 x LM1875. The only logical reason left to use 2 x LM1875 instead of 1 x LM3875 is to use it as a learning exercise.
LM1875 PCB, Which To UseHide this!Advertise here!
LM1875...how low can you go? Gcollier Chip Amps 7 6th May 2010 04:43 AM
How hot does an LM1875 get? Dominique Chip Amps 15 23rd January 2007 03:13 AM
lm1875 siemensc65 Chip Amps 4 23rd May 2006 04:28 AM
Lm1875 soundNERD Chip Amps 14 12th October 2003 03:26 AM
Copyright ©1999-2017 diyAudio
