Old 1st April 2008, 04:19 PM   #11
jackinnj's Avatar
Originally posted by jaste
Wait a second, I havent tried it with a source yet.
All my measurments have been without any source. To me it sounds strange that the chip would get very hot when the power is on but there's no input but maybe that's the way it is and my amp is actually working just fine? If it's so I shouldnt have my amp on when there's no source?
I'm gonna bet that without any input source your LM4780 is oscillating. It would be helpful if you had a scope. You might be picking up some RFI, or oscillating of its own volition.
FWIW, I have been able to get the LM4780 to oscillate as high as 1.5 MegaHertz -- and it gets very unhappy.
Old 1st April 2008, 04:23 PM   #12
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
LM4780 chips produce more offset than LM3875s
It is highly recommended to always have the source connected when amp is on, if no source is connected it's best to short the input to ground.
With source connected, the DC offset us usually much lower too, as the input impedance is in parallel with source's output impedance.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Aleph 30 problem - half of power supply voltage on speakers output yoke Pass Labs 18 15th March 2009 05:18 PM
lm4780 problem Jim Karr Chip Amps 6 13th June 2007 08:56 AM
LM4780: Maximum usable power output yusuf Chip Amps 3 2nd April 2007 11:13 PM
Problem building a power supply, no output after smoothing caps? markiemrboo Parts 11 15th January 2007 05:10 PM
LM4780 instantaneous peak output power capability percy Chip Amps 0 18th October 2004 03:15 PM
Page generated in 0.05706 seconds (72.46% PHP - 27.54% MySQL) with 10 queries
