Question about noise?
Old 31st March 2008, 02:03 AM   #21
Dougie085 is offline Dougie085  United States
Like I said old picture and it was back when I had another thread where I pretty much tried everything.
Old 31st March 2008, 02:33 AM   #22
cuibono is offline cuibono  United States
cuibono's Avatar
I'm under the impression that these amps are not prone to electromagnetic noise (noise pickup from magnetic fields, like transformers) - so I really doubt wiring layout/gauge is your problem. I'd guess your problem is your grounding scheme. What are CHG, PG+ and PG- connected to?
I would connect CHG and the chassis to the power input connector ground directly.
Try connecting your source to the amp with a different cable. I had subtle noise issues that resolved when I got rid of my rat shack interconnect.
Also, is your transformer true dual secondaries (has four wires not three)?
Old 31st March 2008, 02:37 AM   #23
cuibono's Avatar
also, wrt 'danielwritesbac' - the resistor he suggests adding is already there - it is one of the 22k resistors. R2?
the board pic makes it hard to see
Old 31st March 2008, 02:37 AM   #24
Yes dual secondaries. I plan on doing the grounding like Peter showed in one of the threads.
Old 20th April 2008, 12:31 AM   #25
Well I did the grounding scheme just like that thread said. I used a nice thick wire from the wall outlet ground to a star point and then used thinner wire from the 4 connections on the rectifier board and then the thinnest wire used for the inputs. So I had a star ground scheme. Anyways the noise is like completely gone no hum at all. There is a bit of static sound but I can only hear it if I put my ear up to the speakers. Also my speakers are quite sensitive something like 95dB. Sounds excellent now though very happy
Question about noise?Hide this!Advertise here!
Output Noise question ianc13 Tubes / Valves 2 20th August 2007 11:48 AM
static noise question kambrian Car Audio 2 16th July 2005 12:59 AM
LM4780 and noise (question) john_lenfr Chip Amps 12 7th July 2005 06:16 PM
Question about noise from kits. caxxxxxx Power Supplies 3 30th April 2005 01:47 PM
ZenV4 noise question Deafboy Pass Labs 5 18th August 2004 05:22 PM
Copyright ©1999-2017 diyAudio
