Newbie trouble- First Amp Project TDA1517
Old 10th March 2008, 04:51 AM   #1
dj_oatmeal is offline dj_oatmeal  United States
Default Newbie trouble- First Amp Project TDA1517
My son and I just built our first amp project but we ran into issues after powering it up. I used a TDA1517 salvaged from an old audio/video capture card and a DSL modem housing. The rest of the parts are new from Ratshack. We can hear music and a thumping sound out of the left channel. The music is quiet and the thump occurs about once a second. The right channel is dead. We are powering it from a 12VDC 1000MA wall wart. I was using a Sony Discman as a source for testing. I will say up front that I did not give enough thought to my ground implementation and plan to redo it next weekend. The volume control and power switch worked as they should.
Left and right are reversed in the image.
This thread contains the wiring diagram I followed http://www.diyaudio.com/forums/showt...threadid=90487 which I confirmed is accurate per the original spec sheet from the manufacturer.
Any ideas? Thanks.
Old 14th March 2008, 05:20 PM   #2
I see many people have looked but no replies yet. Can anyone comment as to why no suggestions? Is the picture no good or is the whole thing that bad looking that there is no good starting point for helping?
I can upload a bigger picture this weekend if that might help.
Old 14th March 2008, 08:30 PM   #3
norazmi is offline norazmi  Malaysia
hmmm... I suggest better used proto board@simple board for PCB because its looks hard to give suggestion with this situation, maybe peoples dont know which and where... to comments...
Old 15th March 2008, 04:15 AM   #4
DigitalJunkie is offline DigitalJunkie  United States
Send a message via AIM to DigitalJunkie
Try soldering some bypass caps *right on* the chips pins for +V and gnd.
Maybe something like a 0.01uf,and a 22uf in parallel.
It's important that they are very near the chip pins.
Old 15th March 2008, 06:18 AM   #5
gootee is offline gootee  United States
DigitalJunkie's suggestion to solder the power supply bypass caps much closer to the power supply pins is a very good one. Your schematic specifies 100 uF and 0.1 uF from Vp to Gnd. Your photo is not quite large-enough for me to see if the 0.1 uF cap is present or not. In any case, while it is more important for the smaller cap to be closer to the pin, ideally the bodies of both caps would be as close as possible to the chip's power supply pin. (Also, you might want to experiment with connecting the ground end of the caps directly to the Pgnd pin (5).)
Wait. Are you SURE that the photo is left/right reversed?? If it's not (and it looks like it's not), then I don't see either the 100uF OR the 0.1 uF (100 nF) that should go from pin 7 to gnd! That might be your main problem. Solder them directly to the pin, with leads as short as possible, at least for the ones that connect to the pin.
Soldering: When soldering, you should try to use long-nosed pliers as a heatsink, between the device and the solder point. You can use a rubber band on the pliers' handle, for 'hands-free operation'.
I think that your layout and construction technique could be a significant problem. Lead-lengths and wire-lengths should usually be as short as possible, for example. And the enclosed loop areas of to/from pairs' current paths should be minimized. You can tightly twist together any paired wires, to minimize certain loops' areas. Others might depend on your layout being good.
A piece of perfboard, or whatever it's called, should give you a way to mount the components better, enabling you to design a more-compact layout (probably using radial-lead capacitors instead of the axial-lead type). Actually, any piece of thin, stiff, non-conductive material, and a drill, could also be used.
But suggesting a whole different layout doesn't necessarily address the problem you are having right now. Do you have a multimeter? If so, you can do some basic 'sanity-check' types of measurements. I'd start with making sure that the DC voltage between the chipamp's power pin and ground is what you think it should be. You could also measure the AC component, there. I would also disconnect the source and put a short across each input and then measure the DC voltage across each speaker, which should only be a small fraction of a volt.
Does the chip get hot? I cannot quite see how it is mounted. Typically, you would want the entire rear surface of the IC to be mounted against a heatsink. Usually, you would want to make sure that the heatsink is not in electrical contact with anything else.
The electrolytic capacitors ARE the signal path: http://www.fullnet.com/~tomg/zoom3a_33kuF.jpg
Old 15th March 2008, 04:43 PM   #6
Here is a much better picture. http://picasaweb.google.com/oatmealo...91070949438946
Thanks for the feedback at this point to everyone trying to help. My first priority is to try to get it working before making any major changes (like bread boarding it or changing the values of any caps) though I suspect that completely redoing it per suggestions might make my life easier.
I've never tried anything electronic without instructions or in kit form so unfortunately have no idea what readings should be at various points when probing with my multimeter for "sanity checks". How would I determine what readings should be at each point?
It was suggested by a friend that the chip might have been damaged by my soldering so I will replace the chip this weekend. If I can find a socket at ratshack I will solder that rather than the chip.
Again thanks for the assistance.
Old 15th March 2008, 04:57 PM   #7
Yes the chip and the heat sink get hot. It stabilizes just under 180 deg F. The flat tab on the top of the chip is flat on the heat sink. Should I use a bigger heat sink?
Old 15th March 2008, 11:17 PM   #8
Hi DJ, you just mount the TDA1517 chip on the top heat sink like that is not recommended, mout it on the flat heatsink not only top of the TDA ics but all the flat ics surface. I did build amp TDA7294 before, what i know is we must use correct heatsink to reduce ics become heat faster and blown ics in few mins, this is important thing to get correct heatsink for each power ics. Make it simple but be carefull with the heatsink thing that will waste your money
Sorry for my bad language,i hope you can understand. I`m just new in here and try with little help, but i hope more experts peoples will help you out with professional suggestion.
Old 16th March 2008, 01:38 AM   #9
Good point. Heat rises. I'll mount the chip on the bottom of the heat sink and see if that lowers the temp. Is that what you are suggesting or do you mean for me to have the actual black part of the IC in contact with the heat sink? I looked on the spec sheet and see that 180F is near its operating limit so the temp needs to come down a little at least.
Old 16th March 2008, 04:43 AM   #10
Hi DJ, if your heatsink doesnt connect to ground (0V) and yes you can mount the ics directly, but if your heatsink connect to amp case which having ground connection you need to use silicon plastic to prevent electrical shock, i suggest for first powerup or testing your amp better use min voltage like 8volt, in normal operation when the amp in on mode and idle, tda ics should not become hot faster, i suggest before you connect to audio source, just test in idle mode lets see the ics become hot or not, if you have multimeter, you can check whether output having high dc current or not, if it doesnt have then power off, connect the output to the speaker and connect the input to the source, see its working or not.
Newbie trouble- First Amp Project TDA1517Hide this!Advertise here!
Bridging a TDA1517 wadehavens Chip Amps 6 26th October 2011 05:58 AM
hello from newbie + new project Tomac Multi-Way 6 12th December 2003 01:03 AM
Looking for newbie project? more_power Solid State 8 3rd May 2001 01:10 AM
