Old 8th March 2008, 12:38 PM   #11
Puffin is offline Puffin  United Kingdom
Peranders. Is it just Class D where inductors attract RFI ? They say that when modding Class D amps you should shield the inductors (copper) and ground it ?
Old 8th March 2008, 01:18 PM   #12
The Thiele network on the output does two jobs.
1.) it provides a defined load at high frequency.
2.) it attenuates back emf/RFI that tries to enter the feedback route.
Old 9th March 2008, 02:41 PM   #13
Dino-Indo's Avatar
Dear All...
After browsing so many threads in this site, I finally found a way out to solve the humming problem... A separate ground for power and signal (sounds silly eh? ... one of those DIY Greenhorn mistakes I presume...)
I also applied grounding circuit as suggested in Elliot Sound Project' website on grounding a power supply for amp...
So, afterward...humming is VERY SMALL and only on right channel.. only can be heard when gain knob at full volume...
Now.. everything ROCKS!! ...
I really glad to be the member of this forum....
God Bless You All....
Old 9th March 2008, 08:07 PM   #14
ttan98 is offline ttan98  Australia
Originally posted by Dino-Indo
Dear All...
If your chasis is metal sheilded you must not separate the main earth with signal gnd, it is dangerous.
main earth can be connected to signal gnd via a 10 ohm resistor that will reduce gnd loop and elevate danger.
Old 9th March 2008, 11:48 PM   #15
don't confuse the Safety Earth with the Audio Ground, Power Ground, Signal Ground etc.
Old 10th March 2008, 12:07 AM   #16
Dino-Indo's Avatar
Hi Ttan98 & Andrew T
Thanks for your advise...
FYI, the electricity socket from state supply to most housing in Indonesia is having 2 prongs only ... not 3 prongs as in many other country (which one of it is for earth grounding...)...
As to the signal groundings to the chassis, I have attached 22K resistor (please refer to my previous picture).... hopefully it is a safe measure...
Best regards,
Old 10th March 2008, 11:16 AM   #17
gainphile's Avatar
Bagus
http://gainphile.blogspot.com
Old 10th March 2008, 03:25 PM   #18
Dino-Indo's Avatar
Hi Gainphile...
Terima kasih...Thank you.. Arigato...
Actually, one of the posted thread mentioned in my previous reply was yours... Hehehe...
Again... Many thanks
Old 8th May 2008, 02:02 PM   #19
johny is offline johny  Indonesia
hi dino, we have the same source getting the kit . i have the same problem as yours, n i think i'll try your method.
anyway i have several question, before you fix the problem:
1. did you try to connect the amp with any source?
2. did you use input caps?
when i connect my amp with an mp3 player as a source(cheap one ), all of that noise is gone, no hum or low frequencies noise. without a source connected, i can hear that noise from the speaker.
i also try to take out the input caps, an the noise become smaller.
one more think, when i check the DC voltage on the output, its only -0.3mv. is this normal?
thx
Old 8th May 2008, 04:28 PM   #20
Dino-Indo's Avatar
Hi Johny!
I did not use input cap and yes, I did tried out to connect the amp, either directly to the CDPlayer or to my Non OS DAC, both produced very small hiss ... (just recently). I would assume that this might be relate to different impedance issue between the amp and the source...
I did rearrange the grounding cables and use thicker (I think it's a 18 AWG cable) cable for the PS grounding.
- 0.3mV DC output? I assume it should be OK...
FYI ... I also install additional smoothing caps on the PSU, as now I got 6 x 4700uF caps per power rail (total PSU capacitance now 28200 uF x 2... I hope it is not overkill hahahaha...) and I also changed the bridge rectifier with 4 SF4007 sinterglass avalance diodes... the result?? Awesome!!
Jawdropping bass.. its gets punchier and deep... also I noticed mid range and high improved... clearer...
LM3886 based amp- questions Atilla Chip Amps 12 6th August 2008 04:55 AM
My Version of Mauro Penasa's LM3886 Stanley Drake Chip Amps 28 31st December 2006 12:41 AM
LM3886: TF Version or rather T + isolation pad? Bassterror Chip Amps 13 15th April 2006 05:19 PM
Copyright ©1999-2013 diyAudio
