Old 30th June 2008, 05:09 AM   #71
chylld is offline chylld  Australia
Send a message via ICQ to chylld Send a message via MSN to chylld
one thing i've been curious about with my transformer box... there are 2 cables going from the transformer box to the main amp box, each one carries 25v ac. inside the amp box, this gets turned to V+/PG+ and V-/PG-.
so my question: what happens if i leave one of the cables unattached? (i.e. giving the chips only V+ or V-)
Old 30th June 2008, 06:36 AM   #72
Simple answer. It won't work.
You must connect at least one of the PGs to have a ground reference for the amplifier.
Old 30th June 2008, 07:01 AM   #73
what if i have V+ and PG+ connected, but V- and PG- not connected? (that's what would happen if one of the cables wasn't connected)
Old 30th June 2008, 08:05 AM   #74
again
regards Andrew T.
Old 30th June 2008, 08:33 AM   #75
Originally posted by AndrewT
again
thanks for the clarification. reason i asked is because i was afraid it would blow my speakers up:
Decibel Dungeon wrote:
When I reconnected the amp, I found that I had an offset of 34 volts! After assuming that I must have a faulty chip, and ordering some replacements, further investigating found that the negative supply rail measured 0 volts at the amp but -36 volts in the PSU. A wire had come loose in the umbilical from PSU to amp and reconnecting it solved the problem. It was lucky that I had decided to check the DC offset that morning of I would have destroyed a speaker.
Old 30th June 2008, 08:35 AM   #76
it might.
measure the output offsets with the various disconnections that you think are possible.
regards Andrew T.
Old 30th June 2008, 10:02 AM   #77
it might.
ok these are the offsets i've measured (all in +/- volts):
both V+/V- connected: 0.002
only one connected: 1.94
only the other one connected: 0.49
so max of about 2V. i assume that's not a harmful voltage given that the AA (1.5V) battery polarity test is quite common and harmless?
Old 30th June 2008, 10:06 AM   #78
gainphile's Avatar
Never ever test using your 'real' speaker ... buy a $5 fullranger
http://gainphile.blogspot.com
Old 1st August 2008, 01:30 AM   #79
I have build a parallel configuration amp, based on LM4780 chips but have some nasty hiss at low frequency response, but the bass is not gone at all.
My unconventional solution is a use of non-polarized 47uF Ci cap in parallel to 100nF MKT cap.
Gould it be from improper grounding?
Thanks in advance for answers.
Old 1st August 2008, 05:41 PM   #80
post your schematic
regards Andrew T.
New problems with old Gainclone... sek Chip Amps 13 3rd February 2008 11:48 PM
Pass X150 power down Thump solution = Jensen Isomax (RCA to XLR converter)?? kmtkwong Pass Labs 3 10th October 2007 10:45 PM
My Gainclone PCB - Problems? shyfx Chip Amps 20 5th July 2005 11:56 AM
Gainclone Problems; Aahh! raffir Chip Amps 12 22nd April 2003 09:56 PM
the final solution to jitter and PLL problems? hifiZen Digital Source 3 27th June 2002 10:10 AM
Page generated in 0.10104 seconds (79.19% PHP - 20.81% MySQL) with 11 queries
