Old 5th March 2008, 12:01 PM   #11
gainphile's Avatar
You're most welcome !
This is nothing new as I got the information from those links at the start of the article. Just emphasizing few critical points.
Of course there are more elegant and simpler way like using good PCB but I think the concept is the same.
http://gainphile.blogspot.com
Old 5th March 2008, 01:30 PM   #12
Hi Gain,
I think Tom has explained the Safety implications well enough for you to take action AND modify the diagrams in post1.
regards Andrew T.
Old 5th March 2008, 02:14 PM   #13
danielwritesbac's Avatar
Hi Gainphile! I'm so curious. What are the 8 little green Tracon 100v Polyester caps, and what do they do to the bridge rectifiers? It looks cool. . .
Old 5th March 2008, 02:51 PM   #14
Thanks, very helpful post. I'm about to assemble a couple of chip amps and was wondering about grounding. You've solved my problem
Old 7th March 2008, 05:22 AM   #15
gainphile's Avatar
They are snubber capacitors. Supposedly to surpress HF ripple but I really don't know what they do. I just followed the diagram from:
http://diyaudioprojects.com/Chip/Syn...lone/index.htm
Old 19th March 2008, 03:22 AM   #16
Thanks Gainphile and everyone else for the excellent posts.
I've got a couple of newbie questions.
I realize that the exact wire gauges may not be critical, but could you give me an idea of the relative sizes of the small, medium and huge ground wires?
Also, I'm currently finishing up a BrianGT 3875 dual mono chipamp kit (it's been lying around here for a LONG time), and was wondering if it would reduce the hum and thump potential more if it's built with single or dual power supply boards.
GooTees' 'antiparallel' diodes had me a bit confused, so I Google'd 'audio safety ground disconnect' and came across a page on the ESP site with a wiring diagram. I assume that this is what you meant when you talked about adding a bridge rectifier and capacitor?
http://sound.westhost.com/earthing.htm
Again, thanks everyone. This post has got me interested in putting together a hand-wired, thumpless 'black' amp next. That way, the next time my wife asks me what we're going to do with all of my speakers, I can tell her not to worry, I'm building amplifiers to power them
Mike514ml
Old 20th March 2008, 05:07 AM   #17
gootee is offline gootee  United States
gootee's Avatar
Mike514ml
Yes. Figure 3, IIRC.
Old 21st March 2008, 02:36 PM   #18
gmilitano's Avatar
Those small bypass caps on the rectifier bridge reduce the diode switching noises and results in cleaner DC.
Old 21st March 2008, 03:11 PM   #19
I see that the Safety Earth connection is still shown wrongly in post1.
When are you planning to ask the Mods to substitute a safe diagram?
regards Andrew T.
Old 23rd March 2008, 11:42 AM   #20
gainphile's Avatar
I got the diagram with no 5W resistor. How do I update the diagram?
New problems with old Gainclone... sek Chip Amps 13 4th February 2008 12:48 AM
Pass X150 power down Thump solution = Jensen Isomax (RCA to XLR converter)?? kmtkwong Pass Labs 3 10th October 2007 11:45 PM
My Gainclone PCB - Problems? shyfx Chip Amps 20 5th July 2005 12:56 PM
Gainclone Problems; Aahh! raffir Chip Amps 12 22nd April 2003 10:56 PM
the final solution to jitter and PLL problems? hifiZen Digital Source 3 27th June 2002 11:10 AM
Page generated in 0.13564 seconds (77.53% PHP - 22.47% MySQL) with 11 queries
