Old 1st March 2008, 06:53 AM   #1
Paswa is offline Paswa  India
Paswa's Avatar
Angry My Home theater with LM1876, LM1875, LM3876 For Dummies
I'm going to build a good 5+1 channel ht with 2*LM1876, 1*LM1875, 1*LM3876.
Now there is the PCB of LM1876, Which I designed using PCB Express,
And the schematic is the "Auxiliary Amplifier Circuit" as it was in the official datasheet. I just removed the inductor.
Tell me your suggestions.
And this is the power split supply pcb is here -
Old 1st March 2008, 10:25 AM   #2
I don't understand why you think you need different chipamp types for each channel.
Could you explain your reasoning?
regards Andrew T.
Old 1st March 2008, 11:04 AM   #3
Paswa's Avatar
NO...no...
I'm using a LM1876 IC for Front channels, another LM1876 for rear, a LM1875 for center and a LM3876 for Subwoofer.
understand?
Old 1st March 2008, 11:31 AM   #4
that's my understanding.
Why choose three different chipamp types for the different channels?
regards Andrew T.
Old 1st March 2008, 11:44 AM   #5
Paswa's Avatar
ok, this may be a solution, to use two LM1876 for front and rear. and one bridged LM1876 for subwoofer. And one LM1875 for centre.
Yeh, this is the best solution.
Now look at my PCB layout.
Old 1st March 2008, 12:07 PM   #6
jimmy.e is offline jimmy.e  Sweden
power supply board.
check polarity on c3,c4 and c7,c8 (+ is on ground lead)
Take away diods on pcb and buy a standalone diod bridge,that u can screw on the heatsink.
nevermind: iam tired,and shouldnt surf,check boards
Old 1st March 2008, 12:52 PM   #7
Paswa's Avatar
thanks, but, In negative supply rails, the capacitor's positive pole should be connected to the GND, and the negative pole must be connected to the negative.
Old 1st March 2008, 08:21 PM   #8
y8s is offline y8s  United States
y8s's Avatar
Send a message via AIM to y8s Send a message via MSN to y8s Send a message via Yahoo to y8s
if you route pin 15 under the 1K resistor just below it and around the outside of the board, you can then evenly space your input leads if you wanted to use a standard connector there.
Old 1st March 2008, 11:40 PM   #9
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
Get rid of all the copper pours that are not connected to anything. I would suggest trying to make all traces with 45 degree angles only for manufacturing purposes. Also watch for issues with spacing between traces and pads. Your layout has a number of questionable areas where traces appear to be very close to other traces or pads.
Brian
Old 2nd March 2008, 07:34 AM   #10
Paswa's Avatar
thanks, friend, here it is ---
Custom Home Theater Project in New Home, Opinions appreciated. thadman Multi-Way 5 20th November 2008 12:40 AM
Home Theater XOtothelight Solid State 10 11th November 2005 02:06 PM
LM1875 based on the LM1876 datasheet schematic?? w00t Chip Amps 2 14th March 2005 08:23 PM
LM1875/lm1876 single supply? Adam M. Chip Amps 16 7th February 2005 02:06 PM
DIY Amp for my Home Theater ccarrigan Solid State 19 25th November 2002 06:58 AM
Page generated in 0.09631 seconds (79.78% PHP - 20.22% MySQL) with 11 queries
