| Chip Amps Amplifiers based on integrated circuits |
i'm just finish to instaled 2.1 soundsystem in my mom's kitchen.
its dual lm3886 + ETI 150watt ( 4 transistor ) powered by single square 10A transformator 220v/24V - 0 - 24V, 25A diode bridge and 2 x 12.000uf/50V and 2 x 8200uf/50v in paralel, and a pair of 100nf wima MKP/100v at the end. i built this all to replace my previous DIY project, 2.1 of 2 x lm1875 + 70watt bjt amp which sounds to weak to drive my 2 x 3ways especially the 12" woofer and my 10" subwoofer. it runs and sounds well, with more detail and kicking on bass, for mid and hight freq i have to say that the previous lm1875 produce a little more natural sound. i just realized that 1 chanel producing a smooth electrical noise, i thought its from coolcase near of left speakers. sound alike., but when i turn it off/on found yes, it was from my left drivers. so smooth, i find this problem two days after and i don't find this problem before, since test one by one of the three amp before instaling. i put my suspicions for these points : - The transformator is to small to supply power for alltogether runs amp, or maybe the capasitor bank? or the square transformator i/o toroids?. - ETI amp is not match with LM3886 and eats most of all power supply. - less grounding.. for i put the amp up near the roof. - kitchen room is not suitable for any soundsystem except mini-compos, and the refregerator operation may infect to a/c in. - long driver cables, its about 3.5 metres per chanel. your input would might be kill this noise and solve my problem. thks |
#2 |
Input? Exactly. Is there a load at the amplifier's input, directly before the cable starts its long run? Such could be a potentiometer or resistor (parallel--a load). . . But, is it there?
Is there a 330pF (or so) cap at (parallel) the input to stop radio interference? Is there a speaker zobel in place, oh say, 4 ohms with 0.15uF, or anything similar? How long do the DC power lines run before reaching the amplifier boards? If its very long, those boards may need additional capacitiance at the rails. Are the grounds seperate, such as input, output, and power, once met, never meet again? Hey, that's all the ideas I have. Kudos for a cool kitchen sound system.
#3 |
How about starting out with and EMI filter just before the transformer....
Also, are you able to move the system into a different room to see if that affects the noise.... You may very well have a bad transformer....I had a bad one at one point...actually it was a cheap one. Once I changed it all was good.
"I am always doing that which I cannot do, in order that I may learn how to do it" |
#4 | |||
Tks for the kudos, mostly something new for me.
[QUOTE] Input? Exactly. Is there a load at the amplifier's input, directly before the cable starts its long run? Such could be a potentiometer or resistor (parallel--a load). . . But, is it there? --------- the source is from other box ( plastic ), conected by RCA jack. the source is an analog radio, cd rom, mini jack to play music from mp3 payer / handphone and a three point chanel selector. the signal splited to meet the crossover active for subwoofer and tl074's tone control with defeat mode, yes theres a 50K mono pot and 100K stereo pot. i have check signals with earphones, the out signals from this box is clear. Quote:
this is new for me, i usualy put 100K ohm in paralel, but for this project i didn't. i will try your idea for 1st action. Quote:
Pls kindly adv what is the speaker zobel? how's the usage / install? fyi, the woofers is in sit floor boxes, but i separate the midrange, hang at 1,7metres height and tweeters at 2,5 metres. the pssive crossover is also outside the speaker's box. Quote:
its about 15cm long, 1 spin 'em together before met the board. there is additional capacitance. thanks for the precious info
#5 |
dear wboyd,
Thanks for the inputs, and sorry to ask what is EMI filter means? |
#6 | |
Go here and check some examples out - http://www.filterconcepts.com/ac_filters.html But they can be had just about anywhere...I bought a box of them on GreEdBay for about 5 bucks. I have no idea as to what type of power you have coming into your house.....but there are several options available.
#7 | |||
![]() Another fix for crazy noises is to smear on some flux and re-solder the connections, nice, tight, and shiny. Be sure to touch only with a bright clean soldering iron tip. I use #0000 fine steel wool to polish the soldering iron tip whenever its any other color than bright silver. If there's any ceramic caps, hold them with your fingers while soldering, because they can withstand no more heat than your fingers. Quote:
Onto the amplifier's speaker output terminals can go 4 ohms + 0.1uF, or 4 ohms + 0.22uF. Cap at the ground terminal, resistor at the hot terminal, like: - cap resistor + Quote:
#8 | |
i have open the amp and re-soldering some part, change the RCAs and cables with better, also change the stereo pot with new one since its humming when i touch.
so sorry to tell that i was buy a PCB than find some good parts without knowing what 'em stands for I don't really know how they works, but happy to tell that the noise is already gone however i found other noise : the refrigerator is humming louder when i turn on the system! aargh thats my mom's authority. |
#9 |
back
#10 |
the source box
| LM3886 noise issue | zeus_threat | Chip Amps | 25 | 15th August 2008 09:26 AM |
| LM3886 background noise | weatherlight | Chip Amps | 0 | 14th May 2008 10:18 AM |
| Noise problem with LM3886 gainclone | zeus_threat | Chip Amps | 2 | 12th April 2008 08:31 PM |
| LM3886 very prone to mains noise | Andypairo | Chip Amps | 26 | 14th April 2005 02:51 PM |
| Page generated in 0.38112 seconds (31.38% PHP - 68.62% MySQL) with 11 queries |
