Old 26th February 2008, 06:38 PM   #11
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
Originally posted by xiphmont
Oh! related question: the note 'problem here: minimize loop area!' implies that, eg, the voltage rails would also benefit from being braided? Ground return included or no?
For a supply with dual secondaries and dual bridges twist the the V+ and Ground wires together and twist the Ground and V- wires together. The loop area on the PCB also needs to be minimized, which means you want to place the local electrolytic caps as close to the chip's power pins as possible, and have the speaker ground and the two secondary grounds as close as possible.
My LM3875 amps use a supply with dual secondaries and dual rectifiers with large electrolytic caps close to the rectifiers. The power and return lines for each rail are twisted together (to minimize loop area) and routed to the amplifier modules where the bridge grounds and speaker ground are connected through a ground plane on one side of that part of the PCB. On the PCB I use one 470-820uF per rail as close to the chip as possible to keep the loop area between the local tank caps and the supply pins as small as possible. The signal ground uses the ground plane on the other side of the PCB and the ground reference is at the plated through hole of the speaker ground.
Brian
Old 26th February 2008, 06:50 PM   #12
xiphmont's Avatar
Send a message via AIM to xiphmont
...and for CT/single-bridge supplies, with V+/single ground/V-?
"My name's Monty, and I break things."
"Hello, Monty!"
Old 26th February 2008, 06:52 PM   #13
I would braid the V+/GND/V- wires together, but the large capacitor charging currents will mainly be flowing through the V+ and V- wires for a center tapped secondary with a single bridge (with an ideal center tapped secondary, ideal caps, and equivalent resistive loads across each capacitor no current would flow through the center tapped ground wire).
Brian
Old 26th February 2008, 07:00 PM   #14
xiphmont's Avatar
...except for the speaker load currents. :-)
"Hello, Monty!"
Old 26th February 2008, 07:09 PM   #15
There is no speaker load current if there is no speaker
Brian
Old 26th February 2008, 07:22 PM   #16
xiphmont's Avatar
While true, this scenario is also not useful :-)
OK, so to the last remaining question: does the dual bridge actually have a practical benefit for a true monoblock, ie, one transformer, one supply board, one amp, one channel in one enclosure?
"Hello, Monty!"
Single or dual bridge and why? ßart West-VL. Power Supplies 38 18th February 2008 09:47 PM
The difference of Push-pull,Half-bridge,Full-bridge digi01 Chip Amps 0 8th September 2006 02:10 AM
Is it the right way to bridge a dual OP amp? Mickey Chip Amps 1 26th February 2005 11:31 AM
Whats the difference between full bridge and half-bridge SMPS ? skaara Class D 6 3rd February 2005 07:23 PM
Page generated in 0.08344 seconds (76.91% PHP - 23.09% MySQL) with 11 queries
