| Chip Amps Amplifiers based on integrated circuits |
This is the schematic
The blue parts are usually optional parts |
#2 |
And this are the PCBīs
The same PCB can be used with all the componentes or only the most usual and is calculated for the size of some different components but of course the same value There are only a variation in placing Rg With this I understand the grounds returns, itīs greatly based in Elektorīs schematic |
#3 |
The voltage rails are very dimensionated, at all LM3886 can accept 11A and this is not a joke
Same that my LM1875 design there is very clean, no noise, no pops, nothing (well it sound, but good) My power supply is a 24-0-24V, 160 vA and 3,3 Amperes and two 22000uF caps for each channel |
#4 |
I forgott to say that the power suply caps in the PCBīs have 100uF + 10 uF values
#5 |
And the LM3886
| More LM1875 questions(minimized circuit?) | Adam M. | Chip Amps | 14 | 11th December 2011 12:22 PM |
| LM1875 and questions regarding the example application in the datasheet | aempirei | Chip Amps | 24 | 1st July 2010 07:02 PM |
| Basic ground and earth questions | dublin78 | Class D | 2 | 28th March 2007 06:28 AM |
| Ground questions | limey222 | Tubes / Valves | 39 | 24th December 2006 01:09 AM |
| 2 general gainclone questions, and an lm1875 question | Adam M. | Chip Amps | 11 | 4th March 2005 11:53 AM |
| Page generated in 0.07622 seconds (72.62% PHP - 27.38% MySQL) with 11 queries |
