Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Chip Amps Amplifiers based on integrated circuits |
#21 | |
why add a 10 watt resistor and effect the output, with a value of 0.01 ohms, when you can short it?
If it aint broke, don't fix it. If it is broke, fix it. If you can't fix it, take it apart and see how it "worked". |
#22 | |
Account Disabled
so you can set the current limit to protect your amp? |
#23 | |
but in my case, i just wanted te max limit (0.01 ohms) this seems pointless to me.
#24 | |
Account Disabled
I assume you wanted to be able to reach the 10A peak current output limit. The datasheet isn't clear as to if there is any protection if you short the current sensing resistor. My guess is no, as the datasheet mentioned nothing about thermal shutdown. If that is true, shorting the current sensing resistor may lead to permanent damage to the chip. |
#25 |
have you compared these chips with the LM3875?
Miguel |
#26 |
how can 0.01 ohms not cause damage, but 0 ohms can?
#27 | |
if you check the datasheet's SOA chart you'll see that 0,01 ohm with any decent rail voltage can cause some smoke ![]() edit: or calculate it ![]()
Mads K |
#28 | |
Account Disabled
the trigger seems to be a Vbe junction, per the TI schematics. that is confirmed by the formula used to calculate the current sensing resistor: Rcl=0.8/Icl-0.06 (or 0.02, depending which side of the cycle you are on). so a 0.01ohm resistor will limit the output current to 11A - 26A; while a 0phm resistor will limit the output current to 13A - 40A. as you can tell, if the current is large enough, it will make a significant voltage drop on a smaller resistor. more detailed infor can be found in a TI AN as well. the datasheet for 549 seems to indicate that it uses a different protection mechanism. |
#29 |
Hi.
541 or 549 could be used as headphone amp? Thanks |
Thread | Thread Starter | Forum | Replies | Last Post |
Question on OPA549 / OPA541 | methar | Chip Amps | 2 | 4th July 2006 04:21 PM |
Opa549 & Opa541 | kinser | Chip Amps | 4 | 18th January 2005 09:43 AM |
opa541 | sss | Chip Amps | 3 | 6th August 2004 10:27 AM |
My very own OPA541 GC | MikeF777 | Chip Amps | 4 | 9th December 2003 05:24 PM |
How to use OPA549 and OPA541? | JojoD818 | Chip Amps | 50 | 15th November 2003 02:01 PM |
New To Site? | Need Help? |
