OPA541 and OPA549 - Page 2 - diyAudio
Old 11th March 2003, 08:47 PM   #11
Mad_K is offline Mad_K  Norway
Mad_K's Avatar
I depends on what load you are going to drive, and wether you are going to short the outputs.
I would use a 0,1 ohm for opa541am or a 0,15 ohm for opa541ap ina final design. Caddock MP930 looks good here...
Mads K
Old 4th July 2003, 10:19 AM   #12
Matttcattt's Avatar
Originally posted by pundip
Mad_K,
I am thinking about building an amp based on the opa541. What current limiting resistors did you use? Also does anyone know if the opa541's have thermal protection?
Originally posted by Mad_K
Didn't use any Since this was only a test-setup...
Read the datasheet, it's all there
Are you going to be using current limit with your gc? I am not sure I should just short the limit pin to output out limit resitor
i am using the OPA541 and OPA549. im glad you found them good. i just shorted the current limiting pin to output on the OPA541, and to -v on the OPA549.
If it aint broke, don't fix it. If it is broke, fix it.
If you can't fix it, take it apart and see how it "worked".
Old 4th July 2003, 03:11 PM   #13
Mad_K's Avatar
I just left CL pin floating on my latest incarnation with opa541. Maybe I should tie it to the output instead
I'm not shure wether we are current limited at max, or if we now have no CL at all
Anyways, it sounds GOOD!
Mads K
Old 4th July 2003, 03:29 PM   #14
Account Disabled
the datasheet for the opa541 has very detailed instructions on how to calculate the current sensing resistor and its wattage requirement. check it out.
Old 4th July 2003, 07:35 PM   #15
Mad_K's Avatar
Mads K
Old 4th July 2003, 07:36 PM   #16
Mad_K's Avatar
I would use a 0,1 ohm for opa541am or a 0,15 ohm for opa541ap in a final design. Caddock MP930 looks good here...
Ahaaa
Where does it say wether you are current limited or not if you use 0 ohm CLR?
Mads K
Old 4th July 2003, 10:21 PM   #17
Account Disabled
the answer critically depends on the voltage drop off the zero ohm CLR,
Old 4th July 2003, 10:31 PM   #18
Mad_K's Avatar
Ahaaa
-found it here:
http://www-s.ti.com/sc/psheets/sboa057/sboa057.pdf
(table 1)
CLR=0 Ohm -> CL=10A (peak)
Mads K
Old 4th July 2003, 11:38 PM   #19
Account Disabled
the 10A limit is the internal limit on the output devices (that's how the amp is spec'd).
the limit on the positive and negative side is slightly different (about +/- 10%).
Old 4th July 2003, 11:47 PM   #20
Mad_K's Avatar
That's what I figure too. I guess it lets the smoke out when you draw more than that continously
Mads K
Question on OPA549 / OPA541 methar Chip Amps 2 4th July 2006 04:21 PM
Opa549 & Opa541 kinser Chip Amps 4 18th January 2005 09:43 AM
opa541 sss Chip Amps 3 6th August 2004 10:27 AM
My very own OPA541 GC MikeF777 Chip Amps 4 9th December 2003 05:24 PM
How to use OPA549 and OPA541? JojoD818 Chip Amps 50 15th November 2003 02:01 PM
Copyright 1999-2017 diyAudio
