| Chip Amps Amplifiers based on integrated circuits |
Anyone know how resilient the leads are on the LM4702 ? I wish to mount the device under the PCB (along with the power devices), sandwiched between the PCB and the heatsink. But this will mean bending the leads in the opposite direction from the supplied pre-bends, and I am hoping the leads won't snap off !! TIA, Chris. |
#2 |
It is no problem. I do it all the time with LM3875 and it works fine.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#3 | |
Excellent, thanks very much for that. The amps will be mounted inside some active speakers, so I was concerned that unless they were mounted on the main external heatsink plate, they would get too hot. Chris. |
| Steel Leads and Tinned Copper Leads | impsick | Parts | 0 | 19th April 2009 10:01 AM |
| Bending aluminum? | G | Tubes / Valves | 21 | 27th February 2008 05:52 PM |
| Circut bending | guitargully | Instruments and Amps | 4 | 20th July 2005 08:31 AM |
| bending a lot of resistor leads | Wagener | Solid State | 8 | 4th May 2004 03:16 AM |
| bending leads | theChris | Solid State | 6 | 17th April 2003 06:59 AM |
| Page generated in 0.05566 seconds (76.04% PHP - 23.96% MySQL) with 11 queries |
