| Chip Amps Amplifiers based on integrated circuits |
#11 |
The differences between the LME49810 and LME49830 is the 810 has the baker clamp and clip indicator pin. If you look at the two datasheets and the diagrams then you will see some slight differences. Then the 810 has lower maximum bias voltage. May not matter for most FET uses. But you can use any of the National drivers for either BJT or FET output stages.
-SL |
#12 |
Electrons are yellow and more is better!
I'm planning on making a LME49830 based amp because this IC seems to be what many of us have been waiting for. I thought it would be equally big as a LM4780, it's small! Check the mechanical drawing.
/Per-Anders (my first name) or P-A as my friends call me |
#13 |
A question;
The pin "OSENSE" of LME49830 is for a kind of current limiting for output devices?
Best regards, Ozgur |
#14 | ||
From the datasheet we can read following. I attach Figure 1 = typical amplifier application. Quote:
lineup |
#15 |
I am trying to use it as a 20 watt test amp for speaker analisys and was wondering if there are anything to be aware if running it with out transistor in the output stage
#16 |
have you read the datasheet?
You only have mA of output if you omit the output transistors.
regards Andrew T. |
#17 |
I am trying to adjust the bias circuit of the LME49830 but I can not make it work properly. Has someone tried it with Lateral mosfet where the bias voltage between N and P channels needs to vary from about 1 to 3 Vdc. Because of lower gate voltage of lateral I changed the 1.2K resistor in seris with VBE multiplier by 100 ohms....is it correct? Thanks Fab |
| Lme49830 | nickarsow | Chip Amps | 94 | 18th March 2009 08:57 AM |
| Lme49830 | enzedone | Solid State | 6 | 21st February 2008 03:26 PM |
| Page generated in 0.07471 seconds (84.81% PHP - 15.19% MySQL) with 11 queries |
