Old 31st January 2008, 01:16 AM   #1
fusion is offline fusion  United Kingdom
Default wiring up a transformer (brian gts kit)
After soldering up the kit i bought from chipamp.com im pretty eager to test the power supply boards and see if I get the right output from em.
problem is i bought the dual mono kit and have two psu boards... and one transformer with 3 sets of 2 wires. blue and brown are input then i have the pairs of red and black then yellow and orange.
im not sure how to wire these to the ac1 ac2 inputs of BOTH boards. did i need two transformers or does the 3 sets of 2 wires mean i can use both boards with one transformer?
officially confused,
richard
Old 31st January 2008, 09:49 AM   #2
yes, wire up both PSU boards to BOTH sets of secondaries.
The power ground coming from each PSU board will be separate from each other.
I suggest you keep the dual mono set-up and retain the separate audio ground between the channels as well.
When you get around to making this dual mono set-up safe to use you will need to connect the two separate channel audio grounds to the Safety Earth.
I suggest you try using two independent disconnecting networks to make the safety connections. If this fails to give low noise, then direct connection between the audio grounds and Safety Earth may be better but this relies on very close/very short grounding connections between the channels and this can be difficult to achieve.
If all these options/solutions fail to meet your standards then twin transformers is your next route.
regards Andrew T.
Old 31st January 2008, 10:19 AM   #3
might sound stupid but my problem is that i dont know which colours are ground i can guess but... and i dont know what one to connect to either ac1 or ac2 on brians kit....
thanks for the help anyway it was useful
Old 31st January 2008, 11:01 AM   #4
Firstly, build up a mains light bulb tester.
Use it to power up every project for the first time to avoid expensive/dangerous failures due to mis-wiring. And keep it for powering every time you modify any project.
Identify which secondaries are connected together.
One pair go to AC1 and the other pair go to AC2.
regards Andrew T.
Old 1st February 2008, 03:40 PM   #5
so negative and positive of one secondary go to one ac. (ac1) then the other to ac2...
erm ive got two psu boards which is where i get confused....
thanks again
Old 2nd February 2008, 10:02 AM   #6
it sounds like you just need to solder a set of wires to AC1,AC2,ACG1,ACG2 on the transformer or get another transformer.
"I Love To Camp!"
"Comensing Shock Therapy!"
Old 2nd February 2008, 10:23 AM   #7
don't call your AC wire connections positive and negative. That will confuse both you and us.
Flow and return, or Hot and cold, or Live and Neutral are acceptable alternatives that get adopted depending on context. I'm sure there will be other names that get used and are less confusing.
regards Andrew T.
Old 2nd February 2008, 04:24 PM   #8
info on how to wire one transformer to psu PCB is what he needed. even i see that from the first post. not tring to confuse anyone.... at the rate you were giving answers it would have prolly taken 2 more of your posts for him to finally get his answer.
"I Love To Camp!"
Old 2nd February 2008, 06:28 PM   #9
danielwritesbac's Avatar
thanks again
In that case, its perfectly fine to use just one PSU board. Do, however, make the cables to amplifier 1 exactly the same length, and exactly the same length as to amplifier 2.
It isn't necessary to braid, but do keep the hot lines within 1/4" or closer to the ground lines (close to each other).
I have absolutely no idea how to wire the common ground to the case if using a stereo pair and a torrid transformer. Can someone help out here?
Old 2nd February 2008, 08:06 PM   #10
audio1st's Avatar
thanks again
I have attached a picture which should give you a clue how it could look..
There should be a picture on the side of the transformer which you should use to check the colours are the same..
The metal case (if you use one) should connect direct to the mains earth. Both of the ChG's (channel Grounds), should also connect to earth . If it hums then check other threads for info.
Please follow info about safety posted by AndrewT..
Question about CT transformer and Brian's Rev C power supply board maurycy Chip Amps 9 8th December 2009 09:21 AM
I need help with my transformer wiring onform Power Supplies 0 1st June 2008 07:43 PM
Transformer wiring zlast Solid State 2 18th May 2006 10:31 PM
Transformer Wiring? Killjoy99 Parts 4 2nd October 2004 11:00 PM
Wiring of a transformer AudioFreak Parts 20 20th January 2002 02:40 PM
Page generated in 0.10067 seconds (81.29% PHP - 18.71% MySQL) with 11 queries
