New problems with old Gainclone... New problems with old Gainclone... - diyAudio
Old 30th January 2008, 09:26 PM   #1
sek is offline sek  Germany
sek's Avatar
Default New problems with old Gainclone...
Hey fellow DIYers,
recently I unplugged my good old GC modules in order to embedd 'em into speaker enclosures, thus making active speakers with GC amps.
I thought I should take a look at their status regarding robustness, safety and connection quality - before dumping them into wooden enclosures.
It was then that I found out all of them (four channels total) oscillate when not connected to an input source.
All of them are equal (see attachment), inverting topology with fairly low impedance level (1kOhm input, 18kOhm feedback).
I found out it does not matter wether I have:
- an input capacitor,
- a resistor between inverting input and ground,
- any combination of the above (i.e. resistor to ground before or after the input cap).
But it works with a real world input source - or a shorted input respectively.
This leads to the preliminary conclusion that a very low impedance current path from inverting input to ground is neccessary. But why? Non-inverting input is tied to ground with 1kOhm, inverting input (virtual ground point) sees 47kOhm when left open (100k in the attachment have been swapped along the way).
What's going on?
Thanks for any suggestions,
Sebastian.
PS: All channels are working fine when connected to any low impedance source, even after my analysis and parts swapping.
Old 30th January 2008, 09:32 PM   #2
sek's Avatar
The attached layout shows the supply connection and bypassing. Signal ground, power ground and speaker ground meet at the PSU.
With the components shown, oscillation frequency is a clear 260kHz, shape is a beautiful triangle.
Old 30th January 2008, 11:09 PM   #3
digi01 is offline digi01  China
digi01's Avatar
Send a message via MSN to digi01
i think your pcb layout is good.
but you set the input impedance is too low.i prefer (22k input,470k feedback).
and i think the inverting gc must have an input dummy when the amp is ready to launch
z
Old 30th January 2008, 11:28 PM   #4
sek's Avatar
Thanks, that's good to hear.
You actually find this low impedance setting a lot (in GC projects), even National recommend them in their BPA document AN-1192.
I choose it for the low noise level benefit.
What do you mean by input dummy?
Sebastian.
Old 31st January 2008, 12:26 AM   #5
KSTR is offline KSTR  Germany
KSTR's Avatar
Seba,
the answer is easy, yes, the input dummy.
When the input is open, the feedback divider (Rf/Rb) does not work, the circuit's noise gain (the gain when looking at in a noninverting view) is
1 + 18k/(1k+47k) = ~1.4
But you need at least a gain of 10 for the chip to be stable, better 15 or more. Now, your gain also depends on the source's (or pot's) output impedance, if it is more than about 1k you might get in trouble. So if you were to lower R_IN to 1k it would be right on the edge of stability with open input, and you would need a largish input cap and a source that can drive 500Ohms instead of 1k (ah, do the math for the input cap, it is way to small, it gets loaded with 1k or less, as shown. You need something like 47uF or so).
Also, the 220pF can be a problem source, although it is shown in the datasheet it still not a good thing to do, if one follows loop stability theory. Which says for this chip: at high frequencies you need a noise gain (the noninverting gain) of 10 or more.
The 1k an the +IN doesn't matter much, it controlles offset a little but has nothing to do with gain.
That's why normally a buffer is preferred for the inverting config, it's all about controlled conditions ;-)
Ah, R_out (0.1R) is of no worth, unless you put it in to have a controlled output impedance of just that value (but which gets swamped as soon as you use connectors and cables).
- Klaus (greetings from P'Berg, btw)
Old 31st January 2008, 01:29 AM   #6
sek's Avatar
Hi Klaus,
m'kay, I'll take some time to get this sorted.
Damn, I wish it was difficult!
When the input is open, the feedback divider (Rf/Rb) does not work [...] but you need at least a gain of 10 for the chip to be stable
This is actually the answer I was overlooking, spot on!
I had thought about RF, grounding scheme, etc.
But I had forgotten that the LM38x6 is not unity gain stable!
I'm aware of that 1uF and 1kOhm forms a way to high pole (or has a way too small time constant). The values you see are the result of trial and error to find a relation between component choice and oscillation frequency.
BTW, the speaker it powers is a mid/high unit, so no bass is required (but that's not why I chose 1uF, it was just the last update I made to the schematic during testing).
I think it's useful, although too large considering the impedance level. That's probably what you meant.
Who's claiming any different?
It's there to minimize offset, and that's exactly what it does. 900 something Ohm would be better according to my calculation, but 1kOhm suffices to keep offset voltage up to spec (a couple of millivolts).
I thought about leaving it out in the process of troubleshooting, but certainly don't feel the need any more.
Don't laugh, they were intended to get an input buffer. They had originally been designed to become equipped with their respective active crossover filter.
And as they will get their buffer inside the speaker enclosures I plan on putting them in, I'd say all is well!
It's of considerable worth: current limiting in case of an output short.
Nationals protection circuitry is good, but as I wanted the modules to be versatile, I thought: why not play safe.
Sooo, I'd say my best bet is to raise the impedance level by a factor of 10 (using 10kOhm and 220kOhm) and see what happens, right? Could be the solution to the instability, the input filtering and the decoupling problem. I'd say a slightly increased noise floor into the tweeter's voice coil is better than a 30V triangle wave.
Sebastian (greetings from L'Berg, btw)
Old 31st January 2008, 10:00 AM   #7
three options:
1.) fit an input buffer
2.) convert to non-inverting
3.) try fiddling with the impedances to cobble together a badly implemented inverting amplifier.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 31st January 2008, 02:43 PM   #8
sek's Avatar
Hi Andrew,
let's see...
fit an input buffer
Will be done in the future, but for the moment the modules shall be safe and easy to use (i.e. harmless if the wife pulls a plug).
Not possible with the current PCB. I will design a non-inverting amp the next time.
Now I'm interested why you say that. I see inverting GC implementations a lot in these forums and on the net. 1k/21k with buffer or 20k/220k without buffer are very common and tried approaches.
What change to the existing topology (and PCB) would you recommend in order to prevent bad quality and/or instability?
Sebastian.
Old 3rd February 2008, 05:30 PM   #9
sek's Avatar
I've found the time to investigate a little further.
The attached shot shows the oscillation of the low impedance version (1kOhm/18kOhm).
This is measured at the after R_out with open (floating) input.
With the input shorted, the output is almost dead silent.
Old 3rd February 2008, 05:35 PM   #10
sek's Avatar
This next shot shows the high impedance version (10kOhm/220kOhm).
This is with the input shorted to ground, so it's the best I can get with this configuration!
I don't get it. What makes this high impedance version swing, especially at such a high frequency?
Any help is appreciated.
Sebastian.
New problems with old Gainclone...Hide this!Advertise here!
Problems designing an PSU for an gainclone. samsagaz Chip Amps 23 30th August 2007 02:20 AM
My Gainclone PCB - Problems? shyfx Chip Amps 20 5th July 2005 11:56 AM
problems wiring Brians gainclone kit Milkduds Chip Amps 9 12th December 2004 01:47 AM
Gainclone with DC-offset problems seve Chip Amps 11 28th May 2004 11:01 PM
Gainclone Problems; Aahh! raffir Chip Amps 12 22nd April 2003 09:56 PM
Copyright ©1999-2017 diyAudio
