| Chip Amps Amplifiers based on integrated circuits |
#21 |
Where is the 270R on that diagram?
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#22 | ||
The caps for the regs, I have sized for 47uf. Quote:
I also spent some time last night matching the J310's I have some exact pairs and a lot within 0.1 milliamps of each other. I Can get 6 matched to within .4 milliamps of each other. What constitutes a matched pair in peoples opinions? I got a case made today for my measurement mic, I gues I have less than 45 mins to get it completed then I will work flat out on the design above. Regards B |
#23 |
Oops double post.
#24 |
#25 |
What about this one?
![]() I'll try this very soon. I've got the components. There are some differences; - 2u2 used as DC decoupling instead of 4u7.. Why? because I already have 2u2.. However the space is suitable for 4u7 also. - 2SK170 used as J2 as Pedja said. But without R2, bias current increases 10mA. Then to keep it 6mA I put 20R source resistor to SK170.. - Added gate (1K) and input load (100K) resistors to J1... - +/-30v will be used for LM3875... Because I've sold my wharfedale 9.6s.. Now I have only 9.1s and theyre 86dB. So I will need more power.. Thats all. If anybody request, then I can send the eagle files..
Best regards, Ozgur |
#26 |
Well I would stay with the J310 or 2SK246BL
Jfets with high Vgs are more suitable as a curren sources have better rejection more about - W.Jung Current sources in audio circuits. |
#27 |
2SK170 is also a JFET as you know.. So whats the difference?
#28 |
Means, I coulndt find data about 2SJ310.. Does it have really big diffrerence by meaning of Vgs?
#29 |
My latest PCB design.
Tidied up the component sizes, for the 1 uf I have designed for the sonicap Gen1 I have moved the cap to the underside of the board, but printing one sided board Dimensions work out at 43.18x 29.21mm (1.7' x 1.15') ![]() Whats the thoughts? Any errors or better design tips? Had considered a signal earth plane? |
#30 |
bypass before and after the reg... get those pins as close to the reg legs as you can... looking nice otherwise I would route the ground plane a little further from the sk170.... I think it is a high impendance point...
| Pedja Rogic's J-fet buffer for dummies. | Nordic | Solid State | 55 | 18th June 2009 05:19 PM |
| Pedja Rogic buffer + pllxo | joshuajoshua | Chip Amps | 0 | 31st January 2009 05:32 AM |
| WTB: Pedja Rogic buffer board | vizion | Swap Meet | 0 | 16th May 2008 03:49 PM |
| low voltage PSU for Pedja Rogic's buffer | sith | Chip Amps | 5 | 1st February 2008 06:19 PM |
| Page generated in 0.11964 seconds (83.54% PHP - 16.46% MySQL) with 11 queries |
