Old 22nd January 2008, 12:05 PM   #1
vthieu is offline vthieu  Viet Nam
Unhappy prolem chipamp TDA7294
Hi !every body
I first DIY Chipamp with this application schema TDA7294,but the output in pin 14 have 4Vdc. It make the sound very bad . I change 2 chip TDA but nothing . Any one have ideal help me please!
Because I hear TDA7294 very easy to make with some little component and very easy suscessful. Hu hu
Old 22nd January 2008, 01:05 PM   #2
Default DC offset
Are your values all the same as the schematic? are you using the 22K NFB resistor and is the value the same as the input shunt resistor? a difference between the two can result in an offset. Did you include the boot strap if so try a different value cap. Also try raising the value from 680 to 1K for the NFB to ground resistor.
Old 22nd January 2008, 01:30 PM   #3
ashok's Avatar
Check your circuit again . Take a break and look at it after a couple of days. Sometimes you overlook obvious mistakes if you keep spending too much time on it.
The application circuit works very well.
Search for 'TDA7294' on this forum. You will find lots of informatioin and 'warnings'.
AM
Old 22nd January 2008, 02:05 PM   #4
http://www.flickr.com/photos/15683789@N00/2212069488/
I try replace R1 22K link pin 3 (in+) , but no nothing ,I meter pin 14 still -4Vdc ,What can I do ?
Old 22nd January 2008, 02:05 PM   #5
Many thank for your ideal !
I will check it again on another day , when I refesh!But I no found mistake in PCB with little component , what can I do ?
R (in+) pin 3 =22k
R (in-)=680
R link speaker- (in-) = 22K
Old 22nd January 2008, 03:46 PM   #6
m-tech is offline m-tech  Serbia
Check polarity of C2 and C5.
Old 22nd January 2008, 04:12 PM   #7
ashok's Avatar
Remove C2 and C5 . Leave the terminal open ( do not short the terminals ). If the problem goes away then you had a wrongly connected capacitor.
I suspect wrong polarity in C5 but I could be wrong.
If you still have a problem, check the supply pins for proper voltage . What voltages are you using in the power supply?
C3 and C4 are connected with -Ve terminal to ground ?
AM
Old 23rd January 2008, 12:39 AM   #8
C5 : + link spker
- link pin6
C2 : + link pin2
- link GND
Please tell me if I change C5 = 47uF or 100uF what happen?
it still wrong , 4Vdc in pin14?
Vs- = -28 Vdc
Vs+ = +28Vdc
C6&C8 cap for Supply . I think if i wrong conect polary cap -> BUM BUM.But it OK ,I think ghost could be in my PCB.
Old 28th January 2008, 05:09 PM   #9
czbass is offline czbass  China
Send a message via ICQ to czbass
I've destroied many TDA7294s by mistake..
I'll use a LM3886 to make a new amp.
Old 30th January 2008, 08:55 AM   #10
Fossil is offline Fossil  Singapore
check all pins connected to ground, eg, Pin 1 & 4...solder again.
Tda7294 e_fortier Chip Amps 2 27th November 2008 01:33 PM
CSD/Waterfall low frequency noise prolem elvischan917 Multi-Way 1 17th November 2008 11:44 AM
TDA7294. . . help! ;) danielwritesbac Chip Amps 3 19th April 2008 06:58 AM
My TDA7294 Amp panson_hk Chip Amps 1 27th June 2007 01:06 PM
Need help on tda7294 amp Fossil Chip Amps 6 20th April 2005 02:53 PM
Page generated in 0.09976 seconds (75.94% PHP - 24.06% MySQL) with 11 queries
