gainklone problems, maybe...
Old 25th February 2003, 05:47 PM   #41
cowanrg is offline cowanrg  United States
cowanrg's Avatar
Send a message via AIM to cowanrg
well, not to confuse things, im only using one channel.
Old 25th February 2003, 05:51 PM   #42
Steve Eddy is offline Steve Eddy  United States
Steve Eddy's Avatar
Originally posted by Peter Daniel
It is fine, although as I remeber Stereophile review they noted that 170VA supply was a limiting factor to the amp.
Well, John THOUGHT it was the 170VA supply that was the limiting factor, but that notion was incorrect, as stated by Yoshi in the Manufacturers' Comments.
<i>According to Junji Kimura, the designer, the anomaly appearing in JA's measurements is to be expected when the Gaincard is fed a continuous waveform. It is due to the very small filter/capacitor of 1000uF rather than the Humpty power supply itself.</i>
se
Old 25th February 2003, 05:55 PM   #43
Philo is offline Philo  United States
When I first started testing my gainclone, I notice a light popping occasionally, I never found out what it was attributed to because I have changed out every component several times except the the chips, transformers, and bridge rectifiers. During that time the problem has gone away so.... <shrug> Try checking your solder joints, change out your interconnect and plug the amp into a different outlet. All things I have found to cause popping problems, mostly from shorts or bad connections.
Philip
"If you didn't make it with your own two hands, its not really yours".
Old 25th February 2003, 05:58 PM   #44
cowanrg's Avatar
ok. if you saw how it is hooked up, you would probably just look at me and point at it...
some of the wires are even just resting where they should be, not even terminated or soldered. its probably just that...
i threw this one together in less than 30 minutes, so its probably just got issues. i'm going to put together another one today that will be GOOD quality, and i'll do two of them.
Old 25th February 2003, 06:16 PM   #45
Most likely that is the problem. You should always take the time to do the soldering for the signal path. You can save time by using crimp-on blade connectors for the PSU. I even use blade style auto fuses with these connectors.
Philip
gainklone problems, maybe...Hide this!Advertise here!
My new wooden gainklone DT Chip Amps 8 6th August 2005 03:09 AM
Help! Problems with Bridged-Paralleled GainKlone. overmind Chip Amps 4 23rd August 2003 03:02 AM
Zen vs. GainKlone MikeW Pass Labs 26 19th June 2003 08:52 PM
Newbie GainKlone VoLCoM Chip Amps 12 18th April 2003 05:10 AM
Copyright ©1999-2017 diyAudio
