| Chip Amps Amplifiers based on integrated circuits |
#11 |
digi01,
There are cap attached at the signal input and signal output. what value is best to put? 0.47uF? or 1uF?
Regards, C.W. Teoh |
#12 |
i use 100n rifa for input,10uf elna for output.they are not the dedicated value.i just pick up handy
![]() to huy5005, its sound mid-hi,no hi-fi.its no problem play background music in living room a cup of tea z |
#13 |
Tone controls done well is a huge plus.
#14 |
I've built a similar preamp using the IC.
The performance is good but it doesn't have too much headroom. 2 volts will cause the chip to distort. Still ... it does a good job for non-critical listening.
Frank |
#15 |
I've been using Rod Elliott's Project02 tone control with various op amps and am pleased with the performance. I have a LM1036 but haven't yet put it to use. If I remember the specs, it seemed a little noisy. What are you finding to be the limitations for this chip? What don't you like about it? Frank B, your comments made me dig up the datasheet, and max input voltage is shown as 1.6V typ with a Vcc of 12. I had planned to use mine with a LM1876 amp and thought it would be a decent match.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine |
#16 |
It will work well but the Vcc is limited to 12 volts.
You may need to attenuate the level of the sources going to the input a little so as to avoid exceeding the maximum 1.6 volt input. The IC is not bad. It's designed to attenuate the internal IC noise as the volume control is turned down. A nice feature. My main objection to this IC is the input voltage limit. It's limited for obvious reasons ... to eliminate the clipping of the audio when the bass and treble controls are at full boost. On my preamp, I've added 6dB attenuator pads on the input of the chip and Opamps on the output to boost the level by 20dB. The Opamps are powered by + and - 15 volts. I'd give the chip a try. You can adjust the values of the capacitors to achieve the low frequency and high frequency EQ turnover points that suit your needs.
Frank |
#17 |
I don't foresee my signal source running as hot as 1.6V, but your input attenuator idea seems like good insurance. Thanks for the info.
| i need preamp schematics w/o tone control or volume control | hernanstafe | Parts | 7 | 30th January 2008 03:12 AM |
| Tone Control One Knob Need Help | prorms | Solid State | 15 | 3rd September 2007 03:46 PM |
| Tone Control for my GC | aditaquil | Chip Amps | 5 | 6th January 2005 11:39 PM |
| TI's Tone control | JhonDoe | Chip Amps | 26 | 13th July 2004 01:29 AM |
| Page generated in 3.55753 seconds (3.21% PHP - 96.79% MySQL) with 11 queries |
