| Chip Amps Amplifiers based on integrated circuits |
Hello, I've built a amp using the following schematic and i want to know if the optional Ci capacitor must be a "non polar" capacitor. And also i get a hum when no source is connected and it goes away when the source (preamp) is connected and switched, i dont use the Rin. I would also like to know if i can use a input DC blocking cap, if i can what value should i use.
Thankyou for all your answers. Daniel |
#2 |
Ci, in the Negative FeedBack loop, can be a film type or electrolytic. The electrolytic is supposedly better if of the non-polar but I have not heard a difference here. The schematic shows DC coupling on the non-inverting input and AC coupling on the inverting input. I always recommend that both inputs have the same AC or DC coupling. The High Pass Filter formed by these DC blocking caps must be low enough to pass your audio signal. I recommend about 2Hz for the input cap, 1.4Hz for the NFB cap and 1Hz for the PSU caps. This leaves the input LPF and HPF as the band limiting filters for the amplifier. Add a LPF to the input.
regards Andrew T. |
#3 |
Hi Andrew,
I'm new to this and will really appreciate it if you could make your explaination more simple. Thank You |
#4 |
Ci is in the NFB loop. agreed? This is the DC blocking cap and converts the inverting input (pin9) to AC coupled. agreed? The non-inverting input (pin10) is DC coupled. A DC blocking cap should be added here to convert this input to AC coupling to match pin9.
regards Andrew T. |
#5 |
hi andrew i put a 1uf input cap but there is still noise when no input is connected. i cant really call it a hum is more like a buzz it just dissappears when a input is connected.
#6 | |
It seems like your input isn't shielded as it should be. Connect a 100k or bigger resistor between R1 and ground, as close as possible to the input.
Any solution is a compromise. |
#7 |
do i connect the 100k resister before R1 and ground? i did that and i still have this problem.
#8 |
can i be a grounding problem? my amp is built on a strip board.
#9 |
Mine is also on strip board, but I don't have hum at all, I used shielded cables for signal and they don't intersect any other cables. I'm using RCA connectors for inputs and star grounding. On my system the 100k resistor is placed on the connector, before R1 along with 100pF in parallel to avoid RF interferences.
#10 |
well maybe it'll just go away if i put the amp in a case and use shielded cables. i just dont understand y it buzzes when there is no input and become dead quiet when a source is connected.
| Chip amp lm3886 help needed!!! | kanifee | Chip Amps | 7 | 23rd June 2008 09:01 PM |
| My LM3886 chip amp | Denis.BR | Chip Amps | 13 | 19th October 2007 02:15 PM |
| LM3886 or S5 K12M? ...chip or tube | Kenkaru | Chip Amps | 3 | 14th January 2007 02:37 PM |
| A few questions about Building a LM3886 Chip amp??? | Minion | Chip Amps | 21 | 13th October 2006 08:01 PM |
| My LM3886 Chip Amp | bhk | Chip Amps | 9 | 22nd March 2006 12:33 AM |
| Page generated in 0.09960 seconds (78.17% PHP - 21.83% MySQL) with 11 queries |
