Just a note... It is very hard to see where your tracks are cut, the easy way would be to buy the special tool, or you could just use a 5mm drill, twisted by hand where you need the break in the track to be..
Please ignore and sorry if you already know this..
Noise with no input
Hello Daniel. Putting ANY resistor between the input and ground will decrease the amount of noise you hear with no input. Everybody starts from the beginning and that may be near where you are, experience wise. As an electric guitar player with many years of plugging and unplugging, I've heard lots of buzzes & hum with no guitar plugged in to an amp.
Think about it, you have this really eager little IC amp just dying to amplify something and there is no input. So the input wire is an antenna - an electronic nose - picking up everything that may be floating by in your local electro-magnetosphere and amplifies it! With no load to flow through, the weakest fields enter the input lead, even though they have no "push" (current) behind them. The magnetic field around the AC power wires in the house, the flashing of the flouresent lights (I have a flourescent bulb that turns up the volume via the IR remote control sensor on a commercial amp of mine), even a cell phone hunting for a local transponder. All the little bits of electonic fluff look like real signals to an "open" input wire, since there is no load for them to flow through and demonstrate that they are almost nothing at all.
I spent months trying to find out where a persistant, rhythmic, electronic noise was coming from. It was ruining my short wave radio reception. It was an ageing neon bulb in an illuminated wall switch! It was connected to a flourescent fixture and was oscillating due to the resistance and capacitance inherent in the fixture.
If you didn't know a snowflake had almost no mass, the sight of a white object flying straight toward your eye would be frightening. Any amp worth its salt will pickup noise with its input "in the air." Your experienced DIYers just forgot this. Persevere.
I've mounted the amp on a chassis and everything has been grounded through the chassis. the problem is now gone. Thanks for all you help
What do you grounded to the chassis/earth?
- Chip Amps
- LM3886 chip amp help
