| Chip Amps Amplifiers based on integrated circuits |
NuuK. I have put together an LM3886 as per your circuit (the only change being OR22, for which I used a 1R WW res as it was all I had.
I don't appear to have any output (yet seem to read -5v DC offset ?) I have put together a power supply to run it with. the DC +V and -V is 47.3V. I am getting the following readings :- Pin 1 - 3 37.3 Pin 1 - 4 40.3 Pin 1 - 7 32.2 Pin 1 - 8 34.6 Pin 1 - 9 36.3 Pin 1 - 10 32.2 By the way I am getting a strange reading from the PS, +V and OV = 32.5, -V and OV = 15V Any help you can give would be appreciated. |
#2 |
Don't know if photos will help
http://i73.photobucket.com/albums/i2...nsex/chip2.jpg http://i73.photobucket.com/albums/i2...onsex/chip.jpg |
#3 |
First off, are your rails +/-47v or +/-37v?
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#4 |
I believe he is saying his V+ rail is 32.5V and his V- rail is -15V for a total difference of 47.5V. Definitely something odd happening there.
--Sherman |
#5 |
I reckon you have a short somewhere! Disconnect the PSU from the chip and measure it again to make sure it is correct.
Then check for shorts. The chip isn't insulated from the heatsink is it? Check for any shorts. Are you using a muting cap?
#6 |
It is insulated. I have attached th 100uf cap to pin 8
#7 |
And how about the PSU voltages when it is not attached to the chip?
#8 |
Hello Puffin, i can see no V- connection to pin 4..?The neg side of that 1000uf cap connects to 4 as well, with the pos side to ground..
#9 |
I wondered about that as well, but if the neg rail isn't connected, he should be getting the full rail voltage on the output!
#10 |
NuuK. Voltage with chip disconnected +v and -v = 60.6, +v and Ov =32.8, -v and Ov = 27.8
With chip connected +v and -v is 47.1, +v and Ov is 32.10 , -v and Ov is -15v |
| Squeezebox (SB3) modications at Decibel Dungeon | Nuuk | Digital Line Level | 0 | 7th December 2008 11:29 AM |
| Decibel Meter | Staticjeep | Car Audio | 12 | 8th February 2006 08:51 PM |
| Decibel Dungeon GC w/LM3875 | Nordic | Chip Amps | 25 | 11th October 2005 11:06 AM |
| New URL for Decibel Dungeon | Nuuk | Everything Else | 0 | 30th May 2005 07:15 PM |
| 215 decibel !! Could be dangerous | massive | Everything Else | 10 | 29th August 2003 04:27 PM |
| Page generated in 0.09913 seconds (77.64% PHP - 22.36% MySQL) with 11 queries |
