| Chip Amps Amplifiers based on integrated circuits |
Has anybody tried running a DAC like the TDA1543 straight into a chip amp like the LM3886? Do you think there would be any benefit?
#2 |
I've done this in two systems, and also used the lower output TDA1545 (always into LM3875 chips).
With high sensitivity loudspeakers (>94dB) this can be a great solution. If the available gain is sufficient, avoiding extra opamps can provide great transparency. Dynamics do suffer slightly, but this isn't usually an issue if high sensitivity speakers are used. Obviously short, low capacitance interconnects are a must. The best combination I have built so far is a modified Lite DAC-AH (passive I/V mod with 150R resistor) into a 10K stepped attenuator into the LM3875. There is definitely more balls with the paralleled dacs than with a single dac. The output impedance is lowered by a factor of 8 with 8 dacs, as the I/V resistor value has to be lowered. I have tried buffers and active preamps but these always seen to add weight at the expense of resolution, detail and 'air'. I say give it a go, as long as your speakers are fairly sensitive. |
#3 |
Sweet, thanks for the reply. I may try it one day.
#4 |
diyAudio Moderator Emeritus
It would be interesting to try and how you configure the chip amp would depend on the output of the DAC you used. Running the balanced output of DAC into a diff amp would probably be one of the best ways to do it.
Brian |
#5 |
From what I have been reading, a lot of DACs have current outputs and then are turned back into voltage through a I/V converter. I was thinking maybe it would be possible to run this into a chip amp that is set for current feedback (current in/current out but larger current out i.e. current source amp) for use with some of the drivers from Nelson Pass's article on current source amps with fullrange drivers.
#6 | |
Brian |
#7 |
There seems to be a lot of possibilities with this. I will have to check into it in the future when I am done some other projects. A USB DAC that outputs straight to a chip amp seems to be an excellent way to build a small, tight amp.
#8 | |
I am experimenting with a LM4562 buffer into an UCD.
Kind regards, Bert |
#9 |
what is the grounding resistor value for passive mod, 100r or 100kr?
| Which Chip AMP you like most? | dynabok | Chip Amps | 43 | 30th September 2008 08:55 PM |
| Pre-amp for chip amp | wotsascott | Chip Amps | 23 | 30th April 2006 04:24 PM |
| First Chip Amp | doomsweek | Chip Amps | 9 | 10th May 2005 01:55 AM |
| Best possible 10W from chip amp | Robert_66 | Chip Amps | 14 | 2nd November 2004 11:43 AM |
| Hot chip! | batkey | Chip Amps | 1 | 14th October 2004 11:54 AM |
| Page generated in 0.09054 seconds (76.54% PHP - 23.46% MySQL) with 10 queries |
