| Chip Amps Amplifiers based on integrated circuits |
ok, budget for this project is £500 im looking to build up a pair of monoblocks keeping circuitry very very simple but quality of parts as high as i can muster. i was wandering as to which of the kits is the best out there? and then with the follow on questions of transformers binding posts replacment caps ect. ive been looking for ideas as to chassis aswell. i would like somthing very simple as i dont have a major workshop with mills lathes ect. are there any good examples or places online for me to buy from?
thanks. stu |
#2 |
#4 |
Want to spend that much? Then get something with sound quality that matches the price.... http://www.aksaonline.com/buying/buying_price.html
#5 |
chip amp building on payday Post #1
ok, budget for this project is £500 im looking to build up a pair of monoblocks keeping circuitry very very simple but quality of parts as high as i can muster. i was wandering as to which of the kits is the best out there? and then with the follow on questions of transformers binding posts replacment caps ect. ive been looking for ideas as to chassis aswell. i would like somthing very simple as i dont have a major workshop with mills lathes ect. are there any good examples or places online for me to buy from? thanks. stu Well, I build a Gainclone LM3875 using the best parts as I could and the result was a wonderful sound that can easily beat some amplifiers costing more than $1000 us dollars.I used Panasonic capacitors at first,but later I replaced them with "Black Gate" caps $26 US dollars each.but after the change,I noticed the big difference in sound(cleaner,faster).the "Black Gate" caps gave the big kick.so I would strongly recommend to use the best parts as possible(since these amplifier do not use so many parts). good luck with your project!. PS: I am more than happy with my "GAINCLONE LM3875" |
#6 |
You know some people spend more money modifying their minis tham a mercedes costs, but it is still a mini....
I was a little blown out of the water as my first discrete build with cheap parts, blew my gainclone with expensive parts clear out of the water.... Anyhow, not even a $5000 gc will beat one of the Aksa amps... |
#7 | |
diyAudio Moderator Emeritus
Brian |
#8 |
hi all im new to this and have a couple of questions I have tryed serching the forum but I gues being new im not realy sure what I should be serching for.
I would like to build an amp im looking at a ferly tight budget but would like somthing that I can upgrade posibly over time. I found he folowing sight http://www.chipamp.com/lm3886.shtml what else will I need out side of the kit and how mutch is it going tocost to build one of thes amps? any links to a nice build sight would be apreseated blake |
#9 |
I recently bought a dual mono (chipamp.com) kit for $100. You will need to add in the costs of hook-up wire, enclosure, phono sockets and speaker binding posts, mains switch and a transformer (or two) depending on which configuration you go for.
It sounds very good IMHO. |
| building AudioSector chip amp - help needed | jcolton302 | Chip Amps | 10 | 5th January 2009 09:56 PM |
| Building a DAC around AK4396 chip | patherb | Digital Source | 1 | 13th June 2007 05:57 PM |
| A few questions about Building a LM3886 Chip amp??? | Minion | Chip Amps | 21 | 13th October 2006 08:01 PM |
| Pre-amp for chip amp | wotsascott | Chip Amps | 23 | 30th April 2006 04:24 PM |
| PC chip amp | Jennice | Chip Amps | 7 | 6th April 2004 08:03 PM |
| Page generated in 0.11210 seconds (80.33% PHP - 19.67% MySQL) with 10 queries |
