| Chip Amps Amplifiers based on integrated circuits |
Account Disabled
How much do you use?
What Brand? What is your supply voltage? What is the impedence of the speakers you drive? Thanks! -Paul |
#2 |
I don't see the need for more than 1000u per rail, per channel. That gives four caps rated 50V. They are allways from Black Gate, since using so little capacitance, allows to use better brand.
I tried both 18V & 24V on transformer and in both cases it sounded very similar, with 18V providing more bass. I used all kinds of speakers, never had a problem.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#3 |
Account Disabled
Thanks Peter.
I am using 1000uF per rail per channel, random cheap 50V electrolytics. I may have to upgrade them sometime. I was thinking that is where some of my bass has gone. I did try a second set of cables, but it didn't do anything. -Paul |
#4 |
I would try removing 15k resistor to ground after the pot. Maybe it makes your input impedance too low? I tried my gainclones with many different speakers, the bass was always fine. To get better bass, try lower voltage on transformer, 18V or less.
#5 |
Account Disabled
Yeah, I did that already, it didn't help at all.
-Paul |
#6 | ||||
I have 1000uf mounted on the psu pcb and another 1000uf mounted at the chip. Bridges are made with On Semi 100v 10a Schottkys.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#7 |
Hi!
I use 1200 uF 50 V Panasonic FC for each polarity, and again 2 * 220 uF Panasonic FC in the transformer casing (for a little bit of smoothing before transferring the voltage through the cable to the clone) Toroid voltage is 2*25 V, 225 VA (Nuvotem) Speakers: None at all... Only built it for the fun of building, and for testing purposes... but I attached it to 8 ohms speakers (and blew my midrange woofer in initial faulty GC setup...) Bye, Cradle
************************ A Sacrifice For Freedom |
#8 |
only 1000µF per rail?!
I've got 6600 in my class A headphone amp! |
#9 |
How much:
For supply:Started with 1000uf , 50V. Increased to as much as 35000uf, did not cause any audible improvement. Back to 1000uf. For input: 2.2uf , 300V, WIMA MKS Brand: Hitano (Very cheap) Supply voltage: 15-0-15 Prim. 21-0-21 Sec. after standard 20A, 600V Bridge. Delivers 17Watt / channel, that is when it start to clipp. Run at about 30°C on smallish heatsinks. Speaker Z: 8ohm Get more bass then from my Aleph30/ XBoSoZ setup. Sounds extremely good for the price, but not the same as A30.
"Be carefull who's advice you buy, but be patient with those who supply it." From Baz Luhrmann's - Everybody’s Free (To Wear Sunscreen) |
#10 | |
Hi!
And smaller caps are also faster. A lot of people mentioned here that increasing the capacity didn't improve sound at all, even if the caps were directly soldered to the IC pins, so why not stick to less, since I will also cost (considerably) less... Bye, Arndt
| A published LP vs CD survey | SY | Analogue Source | 5 | 17th June 2008 12:46 AM |
| Survey fun! | danielwritesbac | Chip Amps | 23 | 27th January 2008 05:26 AM |
| Audio Survey | AUDIOsurvey | Everything Else | 1 | 22nd March 2006 12:38 AM |
| Survey | audio_noob | Multi-Way | 2 | 11th September 2003 08:02 PM |
| LM3875 Gainclone-current state of the art survey | Dr.H | Chip Amps | 5 | 13th August 2003 07:18 AM |
