Chip Amps with no DC PROTECTION fine? - diyAudio
Old 24th November 2007, 02:58 PM   #1
Default Chip Amps with no DC PROTECTION fine?
i observed that no one includes dc protection for their chip amps, be it diy or commercial ones. is it because no one bothers? or are these chips so reliable that no one should worry?
Old 24th November 2007, 03:07 PM   #2
AndrewT is online now AndrewT  Scotland
a chipamp is an opamp with a high current output stage that can take ~+-40Vdc on it's supply rails.
As such it is a DC amplifier and can and will output DC, if DC is presented to it's input.
If one chooses a topology and/or protection scheme that allows DC to pass through the amplifier then face the consequences, eventually.
Most builders are looking for a low component count, easy to reproduce amplifier. They generally choose chipamps because they see easy buildability without regard to making any design decisions, for good or bad.
It is not reliability or lack of it in the chipamp that is the problem. It is a designer decision.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 24th November 2007, 03:08 PM   #3
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
It's a personal choice really! There have been tales of disaster on this forum but generally, they chips, when properly implemented are as safe as any other type of amplifier.
If you are worried, use one of the speaker protection modules that you can usually buy as kits like this one from Quasar.
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 26th November 2007, 04:27 PM   #4
DreadPirate's Avatar
Would this speaker protection circuit be needed when using a TA2024's "intelligent circuit protection" feature or is that enough?
Old 27th November 2007, 03:36 AM   #5
i have made a diligent search thru this forum and it seems like the cause of such disasters had been due to carelessness.
my actual concern has been on the reliability issues ie. does it known to fail over time, or any other parts of the implementation that fails eg. one half of the PSU failures that may cause the output of the damaging DC.
Old 27th November 2007, 04:26 AM   #6
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Failure of one rail (half of the PS) will not produce DC at the output. The chip is also protected against output being shorted.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 27th November 2007, 05:57 AM   #7
PD, thanks! that has put my worry to rest.
Old 27th November 2007, 08:15 AM   #8
Nuuk's Avatar
And I can add that I have never had any speaker damage from a chip failure using the LM3875, LM3886, or OPA541 chips. So yes, rest assured, if you implement a chip amp properly, you shouldn't have any problems.
I think speaker protection is useful though when you are doing a lot of experimentation where you could make a simple mistake, or you are trying something 'new' and untried! Having said that, I now tend to run anything 'new' on old speakers for a few days rather than risk my better speakers!
Old 27th November 2007, 09:01 AM   #9
This is certainly very good assurance for me. thanks.
Old 27th November 2007, 02:24 PM   #10
fdeck is offline fdeck  United States
I wonder if a possible compromise is to run amplifiers under test, through some big electrolytics wired back to back.
As for DC protection, I think the answer has to be: How safe do you want to make it? My understanding is that DC protection guards against failures such as an output transistor turning into a short circuit. I would be interested in knowing if the audio power amp chips are either: a) Sufficiently reliable; or, b) internally protected, to the point where external protection is unnecessary. The chip amps do have the advantage of instantaneous temperature monitoring of the output devices.
Thoughts?
Chip amps and clipping/protection behavior danielwritesbac Chip Amps 4 28th March 2008 04:58 AM
Need clue. R speaker static when low volume, fine loud, headphones fine. . . Help? danielwritesbac Solid State 4 30th December 2007 03:29 PM
How to 'fine tune' your amps? Family Tubes / Valves 21 31st July 2005 01:26 PM
Has anyone compared the Chip amps against Class T amps? soongsc Chip Amps 3 24th July 2005 11:50 AM
Protection of Mosfet Amps from input Overdrive... Workhorse Solid State 21 22nd June 2005 03:57 PM
Copyright ©1999-2017 diyAudio
