Old 21st November 2007, 02:22 AM   #1
Default Chip phono preamp
I'm looking for inexpensive, but good, DIY moving coil phono preamp. I'm familiar with the phono clone, but it seems that the OP27 is obsolete. Are there other designs or is it possible to update the phono clone to current opamps - perhaps the LM4562 since I have a few?
Thanks!
Old 22nd November 2007, 10:13 AM   #2
is the 627 a near equivalent to the 27?
The thread surely gives modern opamp substitutions.
regards Andrew T.
Old 22nd November 2007, 05:36 PM   #3
Do you mean the phono clone & vsps 'help desk' thread? I noticed that after posting here.
I'll probably do so, but I'm quite intimidated by a 100+ page thread. I'll probably read it backwards.
Thanks for the reply. I'll check out the 627.
Old 22nd November 2007, 06:24 PM   #4
Juergen Knoop's Avatar
OP27 from Analog Devices and OPA27 from TI are still active.
Jürgen
Old 23rd November 2007, 09:18 AM   #5
Electrons are yellow and more is better!
peranders's Avatar
OPA637 is slightly better in a high gain application such as a phono amp.
/Per-Anders (my first name) or P-A as my friends call me
Old 23rd November 2007, 09:20 AM   #6
peranders's Avatar
If you compare datasheets, these devices are quite different.
Old 23rd November 2007, 11:20 AM   #7
nelsonvandal's Avatar
LM4562 is low-noise, and in spite of having bipolar inputs has low bias current. It sounds qite good with a very clean treble and nice bass. Compared to FET-input opamps, it's a bit cold or sterile and give the impression of having a recessed mid. I don't know what gain there is in this RIAA stage, but DC-offset could be a bit higher than with OPA627. Since there's no volume control in front of the RIAA stage, bias current can be balanced. I can't see why you shouldn't try LM4562 since you already have them, and since OPA627 is very expensive and hard to get and soon there will be OPA827 available.
Old 23rd November 2007, 03:20 PM   #8
I've found a few vendors that indicate stock of the OPA627, but they average around $38. Yeah, that's too expensive for me.
How about the OPA227? Would that work?
Oh, and when do they expect to have the 827 available?
Thanks.
Old 23rd November 2007, 03:24 PM   #9
Nordic is offline Nordic  South Africa
Nordic's Avatar
opa 227 is a diffirent beast alltogether... pretty hard to stabalise and will sound thin and uninvolveing if all is not 100%...
give those 827's a chance...
Old 23rd November 2007, 07:02 PM   #10
I don't know, but some claim they've already got samples.
Give LM4562 a shot. If you want a warmer tonality - use OPA2134 (cheap, easy to find) for one stage and LM4562 for the other. Toghethter they'll give a warmer than neutral tonality (at least they do in my headphone amp). LM4562 can be a bit cranky, but just use decoupling caps in close proximity and have a good shield and ground. LM4562 is very prone to pick up radio interference.
The most neutral match for LM4562 I've found is LMH6654, but that amp has very high bias currents and the max voltage supply is +/- 6.
Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps MartyM Tubes / Valves 3 16th October 2008 04:52 AM
new phono stage or old preamp with phono? flohmann Analog Line Level 2 2nd October 2008 09:51 PM
simple chip phono preamp dewdude Chip Amps 4 23rd May 2008 04:37 PM
Dual phono chip carlmart Chip Amps 5 27th July 2005 03:22 PM
Single chip MC phono stage DrewP Analogue Source 12 7th August 2002 02:42 PM
Page generated in 0.10513 seconds (88.47% PHP - 11.53% MySQL) with 10 queries
