Old 18th November 2007, 09:48 AM   #1
Puffin is offline Puffin  United Kingdom
Default Problems with Chipamp (LM3886) BrianGT
I have just completed the Dual Mono 3886 kit with dual power supplies. Power Supplies work, the amp boards are getting DC, but I get no sound. I am measuring <47milliamps at the speaker terminals (at least that's what the meter is showing me), but when connected to speakers, they just sound dead, no hiss, no hum. Any ideas ?
I am intending to use it as a power amp. Have I missed something ?
The amp is in standard configuration (i.e no feedback cap used)
I am getting about 22vDC to the amp board. Is this enough (twin 15v AC taps) I have a larger 30+30 vac if it needs it ?
Old 18th November 2007, 11:05 AM   #2
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Can you show us some hi-res close-ups of the amp? Sounds like a wiring problem somewhere.
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 18th November 2007, 11:37 AM   #3
NuuK. Not sure if these are good enough. I would assume that by the fact that I am getting DC at the amp board, that the wiring to that is o.k. The Red & Blue wires to the mid right are Sig in+Sig Gnd and to the left Sig Out and Gnd Out.
http://i73.photobucket.com/albums/i2...x/PowerBd1.jpg
http://i73.photobucket.com/albums/i239/saxonsex/Amp.jpg
Old 18th November 2007, 11:49 AM   #4
Nuuk's Avatar
Have you checked both rails to make sure that you get the +/- voltages? If so (with something playing) measure the signal at the input phono socket, see if you have a signal at the amp inputs.
Check for a short between the signal wires too!
Old 18th November 2007, 01:08 PM   #5
NuuK. between PG- and V- I am only getting 0.9v Pg+ and V+ are giving me 24v. Is this the problem ?
Old 18th November 2007, 01:21 PM   #6
audio1st's Avatar
Have you got the polarity right? Does V- goto V- on the power supply board and the same with V+, PG+ and PG-. Using the same colour wires make it difficult to tell. Between V+ and V- should be over 30V.
Old 18th November 2007, 01:31 PM   #7
Nuuk's Avatar
43-44 volts to be precise! Or in other words between ground (PG+) and positive you should get +21-22 volts and between ground (PG-) and negative you should get -21-22 volts.
Old 18th November 2007, 01:33 PM   #8
Audio1st. the instructions on Brian's site are to wire the PS wires like for like e.g V+ to V+ on Amp Bd, V- to V-, PGND to PGND etc.
I have measured the voltage between V+ and V- and I get 21volts.
What has just occurred to me is that the PS borad is designed for Stereo applications. It has 2 AC connection points AC1 and AC2. I could only get the LED to light (which is said to confirm that the PS is working) by connecting one set of secondarys to the same side (AC1). It may be that I have only got power to one side of the PSU board.
Here is a link to Chipamp.com
http://www.chipamp.com/docs/lm3886-manual.pdf
Here is a picture from the site. AC1 and AC2 are between the Diodes. If you click on the picture it will enlarge.
http://www.briangt.com/gallery/lm3886amp/proto_amp_4
Old 18th November 2007, 01:37 PM   #9
john65b is offline john65b  United States
john65b's Avatar
Do you have a Center tapped transformer or is it a dual secondary?
The conections to the PS board for the two are quite different
"I speak Spanish to God, Italian to Women, French to Men, and German to my Horse" - Charles V
Old 18th November 2007, 01:38 PM   #10
Dual Secondary.
BrianGT 680W LM3886 Amp krips Chip Amps 33 10th May 2009 10:02 PM
BrianGT chipamp.com dual mono lm3886 amp valleyman Swap Meet 8 21st October 2008 10:43 AM
BrianGT's LM3886 board, and hiss Russ White Chip Amps 9 20th March 2005 08:10 PM
BrianGT's LM3886 Kit scott_jcp Chip Amps 11 4th March 2005 07:07 PM
Which BrianGT chipamp kit to buy scott_jcp Chip Amps 8 24th February 2005 07:02 AM
Page generated in 0.10207 seconds (77.46% PHP - 22.54% MySQL) with 11 queries
