Old 12th November 2007, 10:57 PM   #1
Default amp power advice
I would like to have advice about the minimum power I should use to drive a pair of loudspeaker I did myself. They are made of Vifa PL18WO0908(87db) and SEAS H1149(90db).
I was thinking to try the kingrex amp. Is it enough power ?
http://www.obadimports.com/catalog/i...02/4379642.htm
Thanks,
Simon
Old 13th November 2007, 06:22 AM   #2
Paswa is offline Paswa  India
Paswa's Avatar
Thats ok, u can drive ur spks.
The amp is expensive, n the psu is very well built
but one thing, the rated power is quite low but the THD+N is high, it is 10%.
-Power output:
>>22W @ 4 Ω, 10% THD +N, VDD=13.5V
>>13W @ 8 Ω, 10% THD +N, VDD=13.5V
but my advice, just build a amp using LM1875(20W mono) or LM1876 (20+20W stereo), and then drive ur loudspeaker, LM1875/1876 has a very very low THD+N, it is not more that 1% in even at 25Watt!
now the decision is urs.
Old 13th November 2007, 06:36 PM   #3
and what about audiosource amp ?
Can I use audiosource amp with kingrex PSU if it's well made ?
I don't really want to build my amp myself. Do you have great T-amp to suggest me ?
Thank,
Simon
Old 14th November 2007, 02:17 AM   #4
Paswa's Avatar
ok, before buyin any amp you have to know the maximum wattage that the speaker can handle, then buy a amp of the wattage range.
if ur speaker can handle 100-120W then the Audio source amp will be perfect. n this has a built in psu, so no need to use any other one .
http://www.amazon.com/AudioSource-Am.../dp/B00026BQJ6
Old 14th November 2007, 07:57 PM   #5
Ok the tweeter I'm using support max 55W so I guess this audiosource amp is perfect.
Should I use the equalizer:
http://www.amazon.com/AudioSource-EQ...5073679&sr=1-9
and preamp:
http://www.amazon.com/AudioSource-St...073755&sr=1-39
Would this be a good system ?
Thank,
REALFLEO
Old 14th November 2007, 08:31 PM   #6
Do you have a good quality T-amp to suggest me around 500$. A T-amp that can power 2X50Watts ?
Old 15th November 2007, 01:04 AM   #7
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
By the look at the internal photo of amp,it's good one,just why normal grade VR???
Old 15th November 2007, 05:07 AM   #8
Paswa's Avatar
will u only drive the tweeter? no any midrange or sub/woofer?
A 50Watt amp system+equalizer that u choose, will be a simply very good audio sys.
will u use it with ur computer, DVD player or other mains-fed system. If u use it with that, u need noa any pre-amp.
If wanna use it with electric/acoustic guitar pickup, u need the preamp
Old 15th November 2007, 01:48 PM   #9
I'm gonna drive a Vifa driver that can handle 100W and a tweeter of 50W.
I'm planning to buy a good cd player and a turntable. Does this preamp can do the job ? Should I buy this preamp with the amp ?
Thanks,
REALFLEO
Old 15th November 2007, 02:57 PM   #10
Paswa's Avatar
in this purpose u won't need the preamp. only the amp will do the job very well.
my suggestion, ur speaker can handle 100W, tweeter can 55W. now if u buy the 50W STEREO amp, there would b a lose. as ur misrange can drive 100W, i'd suggest u to buy a 100 W tweeter, then u can buy 100W amp and u can drive the lspeaker and the tweetere with a awesome sound quality.
but if u not wanna spent any more, just keep this config, it will be veeeery fine.
n the buyin amp is ur choice. any 100 Watt Stereo amp will be very fine.
browse thru amazon or radioshack or maplin, u'll find the best amp 4 u.
Hope a happy sound life, Thankz, Paswa
need power supply advice for future power amp project. boricuaso Chip Amps 13 6th February 2008 02:24 PM
Pre-amp power iron advice?? Craig405 Tubes / Valves 25 5th July 2007 05:40 PM
Need high power advice. CJ900RR Chip Amps 6 1st March 2007 07:58 PM
pre / power advice needed! RevF Solid State 3 15th December 2003 11:11 PM
Need advice on low power amp nitropowered Solid State 5 18th June 2002 04:21 PM
Page generated in 0.09974 seconds (78.33% PHP - 21.67% MySQL) with 10 queries
