| Chip Amps Amplifiers based on integrated circuits |
Hello all,
I am new to DIY audio and I am preparing to make first leap into the hobby. I am assembling a chipamp with the following components. Audiosector 3875 Chipamp -2 separate amp boards -Chosen over the 3886 for its higher output at 8ohms -Reasonably priced and easier to assemble than point to point Audiosector Unsnubbereized PS board -single pcb for both channels -I am currently indifferent on the PS being snubberized or not (haven't established a taste yet) AnTec toroid transformer (45USD w/shipping) -single 300VA with 2 32volt secondaries (one per channel) -chosen over 200VA because price was not much more Typical PC-style power entry module/switch with 3amp slowblow fuse Plate aluminum enclosure w/ RCA in/out connectors / 18 gauge wiring Soundblaster External USB soundcard as a preamp -already has a pot for vol. control -okay DAC -fewer grounding troubles And that's it! How could I add a power-on indicator light on this circuit? The lowest voltage I can tap is 32volts, and that would take one heck of a resister to regulate an LED. Any ideas? Incandescent in parrellel with 32 volt powersupply output? Anyone know the dimensions of the Audiosector boards? (Especially the distance between mounting holes) Speaker power suggestions? (50-100 watts/channel correct? Is it that simple?) I appreciate any suggestions any of you can make. It seems to be a typical setup, so I hope I haven’t made any glaring mistakes. Thanks, -Brandon |
#2 | |
R = (32v - 2v) / 0.01A (aka 10 mA) R = 30 / 0.01 R = 3000 = 3k Then wattage would be P = 32v^2 / 3000R P = 1024 / 3000R P = 0.34W Take in to account mains fluctuations etc it may be wise to go with 0.75W - 1W maybe. They're not really that huge! |
#3 |
diyAudio Moderator Emeritus
You could just use 3 common 1k 0.25W resistors in series instead of a 3k 1W resistor.
Brian |
#4 |
You can always add another winding to your transformer...grab some wire...wrap it around transformer until you get the proper voltage needed.
"I am always doing that which I cannot do, in order that I may learn how to do it" |
#5 |
The easiest way to add a power-on indicator light is to use a rocker switch with a light built in. You can pick them up at almost any electronics store for a buck or two. They are usually available with red, orange, green or blue lights. I've used them in everything from chip amps to tube amps with no problems at all.
--Sherman |
#6 | |
1/4W 10k will do
3mA is more than enough for an LED. More appropriate rails are about 35V. So, lets say 35-2V = 33V 33V x .003= 0.01W Quote:
To get the DC voltage you take AC voltage and multiply with the sqaure of 2, which is roughly 1.414... or take the DC voltage and divide by 1.414 to get the required AC transformer voltage. To save you some time, for 8R loads, a 25 to 26V ac transformer will give you about 35V volts when all is said and done. Your 30V transformer would give over 42V of DC... |
#7 | |
Brian |
#8 |
Indeed I did, quarter past one in the morning and all that
#9 | |
The board size (both amp and PS) is 1.2 x 2.9, distance between mounting holes 2.6" . More info here: http://www.diyaudio.com/forums/showt...425#post584425
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#10 |
I'm glad I posted here before I sent out the order.
That would have been an expensive slip up with the transformer. Nordic, you just saved me a bunch of frustration. Thanks a lot! |
| can u name this component? | larrellio | Parts | 10 | 19th August 2006 03:56 AM |
| Component selection for best performance (LM3886). | CJ900RR | Chip Amps | 0 | 24th February 2006 02:10 PM |
| Component selection | eitanwaks | Tubes / Valves | 31 | 4th February 2006 06:27 AM |
| A basic chipamp in a not so basic case. | waltson | Chip Amps | 19 | 24th August 2005 07:40 AM |
| Need help on speaker design, and component selection | BrianGT | Multi-Way | 5 | 5th February 2002 03:39 PM |
| Page generated in 0.10864 seconds (81.26% PHP - 18.74% MySQL) with 11 queries |
