Old 6th November 2007, 12:27 PM   #1
h3ad is offline h3ad  Australia
Default interesting idea :D
hi i have a blown up 5.1 channel receiver that is completely functional except the amplifer is blown (had 2 remove 3 channels to make the amp turn on)
so i am wondering is there and IC amplifer chips i can run on 56-0-56V DC??
thanx
haydn
Old 7th November 2007, 01:34 AM   #2
amc184 is offline amc184  New Zealand
amc184's Avatar
Not really. There are some more obscure Sanyo ones, but as far as I'm aware, they are hard to get and the performance is fairly poor. If you want to use a 56V power supply for something, have a look at discrete solid state amps, or a LME49810 driving a discrete output stage.
Old 7th November 2007, 02:44 AM   #3
whata bout just using a single rail, and configuring a LM3886 to single rail mode?
Old 7th November 2007, 03:37 AM   #4
amc184's Avatar
Not really a great idea, but you could do it. It adds alot of complexity and addition components, which will degrade the sound quality. You should do one of two things if you want to build an amp out of this supply:
- Use a LME49810 to driver a discrete output.
- Go for a discrete solid state amp.
However, it would be easier and cheaper than both options to just build a new lower voltage power supply and a kitset LM3886 (try chipamp.com). How good is the power supply leftover from this old amp anyway? Post the make and model.
Old 7th November 2007, 08:58 AM   #5
the unit (except the 5ch amp module) is 100% working... all the caps n such r pretty fine
anyway the amp is a Sherwood RD-6405
Old 12th November 2007, 02:41 AM   #6
Ipanema is offline Ipanema  Malaysia
Ipanema's Avatar
You can use step down regulated power supply to reduce 56Vto around 35V so that LM3875/86 can be use. Either discrete or integrated regulator will do.
Regards.
Old 12th November 2007, 03:03 AM   #7
frugal-phile(tm)
planet10's Avatar
I did something sort of similar... a blown Technics that we stuffed a pr of 3875 chipamps into. The rail voltage is just a bit higher than the max spec. Driving 16 ohm loads this is one of the best GCs i've heard yet.
So if you don't have low impedance speakers, you would not need to throw away as many volts.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 12th November 2007, 03:59 AM   #8
i was considering 2 regulate... but then i managed 2 resurect the Left and Right channels of the amp module... i dont think theres any chance anytime soon of fixing the centre channel....
so thnx for your help n suggestions guys much appreciated
haydn
Old 12th November 2007, 12:42 PM   #9
judtoff is offline judtoff  Canada
I ran LM3875s of 42V rails, and they didn't like it. I wouldn't do 56V rails at all. You could use 35V regulators as already suggested. Just make sure they have an adequate heatsink on them
Old 13th November 2007, 12:58 AM   #10
frugal-phile(tm)
planet10's Avatar
Interesting. I have one on something like 44V rails and into 16 ohms is one of the best sounding chipAmps i've heard.
dave
Interesting Pro idea based on 6ND430 Zero Cool PA Systems 8 21st May 2007 11:53 AM
Interesting output stage idea keantoken Solid State 18 15th November 2006 11:41 PM
interesting idea from car-audio theChris Solid State 3 25th July 2006 04:42 PM
Interesting idea to make MM carts sound better... Mr.Radar Analogue Source 29 16th November 2005 11:14 AM
Interesting enclosure idea: GrahamnDodder Chip Amps 1 21st October 2003 08:23 PM
Page generated in 0.22956 seconds (34.47% PHP - 65.53% MySQL) with 10 queries
