| Chip Amps Amplifiers based on integrated circuits |
I'm interested in building a stereo amplifier. I came across a lm3886 which would require me to use two satisfy my stereo requirements. Next i found the lm4780 which essentially has 2 lm3886 in it. Are there any advantages of using 2x lm3886 over the single lm4780?
#2 |
the two channel version is probably made to reduce assembly costs on a production line. I think the 3886 with separate power and ground lines for each channel will perform better since the currents are halved and the crosstalk will be reduced if laid out correctly. Two competely separate monoblocks will perform better than a stereo amplifier and each can be located right beside the speaker terminals bringing the very big advantage of extremely short speaker cables.
regards Andrew T. |
#3 |
but remember that if using 2 devices you need 2 sets of bypass caps on Vcc/Vee -- not a huge expense, however.
you can use 2 LM4780's in parallel mode for a steroidially enhanced amplifier. |
#4 |
It may be due to implementation and power supply differences, but my simple stereo LM3886 has much better sound quality than my LM4780 BPA. They are as different as chalk and cheese in their layout and the power supplies have no resemblance to each other, though.
Another advantage of 3886 is heat dissipation and the availability of an insulated package (both sort of work against each other, though). that makes for larger allowable package dissipation or easier construction. |
#5 |
the only advantage i see to the 4780 is cost efficiant, more simple in production runs, cheaper.
and the thing that i like most: building compact stereo amplifiers. i built a full power stereo amplifier that used this IC, and it fits in the palm of my hand. ![]() and used a couple of small higher current boost converters. one thats a boost inverter. that way i eliminated the size of complexity of a flyback supply.
#6 |
Ok thanks for the responses, I'm aiming for a compact design, the lm4780 seems to be the best approach for me at this point.
Does anyone have any suggestions on a better chip amp along the same lines of the lm4780 |
#7 | |
When it comes to chip amps, the amp part usually takes much less space than the PSU and the connectors, so I really don't think one using LM4870 will be any more compact than one using two LM3886's!
In addition (and you don't say how you are going to build this amp) the pins on the LM4870 are closer together than those on the LM3886. If you are hard-wiring the amp, the LM3866 will be a lot easier! If not you will need a PCB. Quote:
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#8 | |
I am planning on building a 50 Watt stereo amplifier. Also, i will be using a PCB |
#9 | |
regards Andrew T. |
#10 |
Hello nicku1302.did you ever though about a LM3875 chip?
I just got one build(integrated amp)and it is very good,simple and it does not get hot at all.I am very happy with the result. |
| LM3875 vs. LM3886 vs. LM4780 | SRMcGee | Chip Amps | 27 | 6th March 2010 05:38 AM |
| for sale: lm3886 and lm4780 | elementx | Swap Meet | 2 | 21st July 2006 03:14 PM |
| lm3886, lm3875, lm4780 | elementx | Swap Meet | 1 | 31st January 2006 11:32 PM |
| lm3886, lm4780, | elementx | Swap Meet | 4 | 29th December 2005 02:44 AM |
| LM3875 vs LM3886 vs LM4780 | ShieldJaguar | Chip Amps | 40 | 17th November 2004 01:26 AM |
| Page generated in 0.10691 seconds (80.31% PHP - 19.69% MySQL) with 10 queries |
