Bridgeclone - Page 7 - diyAudio
Old 6th June 2003, 09:36 AM   #61
Cobra2 is offline Cobra2  Norway
DIY !
Cobra2's Avatar
Send a message via Skype™ to Cobra2
Default Re: Re: ....Bridge/paralell ...
Have tried trim-pots for nulling DC-offset, but something does not add up....
I did de-solder the output-resistor, and null each chip (some variation here), checked and fine-tuned after 30min.
Then re-soldered, and now I have ~20mV ?
It seems that there is a difference when adjusting towards ground and between chips. What gives?
As mentioned...the production-spread among these chips are larger than life...
Arne K
Don't believe everything you think...
Old 6th June 2003, 11:06 AM   #62
Previously: Kuei Yang Wang
Default Re: Re: Re: ....Bridge/paralell ...
Koinichiwa,
Arne K
First, Jeff Rowland uses 0.5R Output Resistors, worth going up to anyway.
Secondly, I suspect there are some interactions between the chips. Try nulling offsets with the chips connected normally and repeat a few times while the Amp settles it's temperature. It is clear that JR does not employ Servos (he seems to share my dislike for their sound) and if he can so shall we DIY'ers.
Sayonara
Old 7th June 2003, 01:27 AM   #63
popes is offline popes  South Korea
Send a message via MSN to popes
Default am I right?
offset null..
am i right?
Kurt
Old 7th June 2003, 01:47 AM   #64
Default Re: am I right?
Koinichiwa,
Originally posted by popes
offset null..
am i right?
Wrong. In your case use a 470K (18 turn) Pot. in all seriousness, for your schematic a dead short ot 22k will make little difference.
Sayonara
Old 7th June 2003, 04:01 AM   #65
Default thanks, Kuei Yang Wang
what do you think about my project?
opa548 3pararel bridge(use 548 6ea for one chanel )
i will use input R 6.2K ohm
feedback 100K ohm
offset null 470K ohm (multi turn)
Kurt
Old 7th June 2003, 10:10 AM   #66
Default Re: thanks, Kuei Yang Wang
Koinichiwa,
If you like the sound of th OPA's /
feedback 100K ohm
YOU will need around a 10K multiturn offset trimmer, as you do not employ a DC blocking capacitor in the input to each chip.
Sayonara
Old 7th June 2003, 10:30 AM   #67
Default dc blocking capacitors
i will use input transformer lundhal 1544A
if use transformer , is the DC block capacitor necessary?
thanks Kuei Yang Wang
Kurt
Old 7th June 2003, 10:32 AM   #68
Default Re: dc blocking capacitors
Koinichiwa,
No, but leaving it out means the value of your offset trim resistor changes, that's all.
Sayonara
Old 7th June 2003, 10:38 AM   #69
Default another question..
how much value need for me??
thank you very much
Kurt
Old 7th June 2003, 10:46 AM   #70
Default Re: another question..
Koinichiwa,
Hey, I forgot, the OPA's are FET input I think, so you cannot null the offset the same way as on the LM3875/3886. Simply use 0.47/0.5R output resistors, ground the non-inverting input and hope for the best.
If they are not FET Input your Pot needs to be around twice the value of all the resistors that are not DC blocked on the inverting input in paralell, so in your case 6k2//220k*2 = 12k - NPV is 10k.
Sayonara
Bridgeclone - Rowland Concentraclone ThorstenL Chip Amps 30 17th January 2014 06:38 PM
opinions on this mod to the bridgeclone? theChris Chip Amps 0 5th February 2004 07:13 PM
Bridgeclone question B.VDBOS Chip Amps 9 2nd September 2003 07:56 AM
Copyright 1999-2017 diyAudio
