| Chip Amps Amplifiers based on integrated circuits |
First post here, I hope someone can help me with my project.
I did a search but couldnīt find an answer to my problem. Iīve put together 3 different LM3886 application circuits from the datasheet.. same problem with all. I put together the split supply schematic using a +/-18V 3A power supply. All three circuits work perfectly... but present the same problem. After a few seconds of perfect and cristal clear playing, the audio peaks begin to distort and the audio output sort of stutters. I find it hard to believe that this is a heatsinking issue because Iīve tried several and have settled on a massive block Iīve cooked up joining (with screws and thermal paste) three large heatsinks. I also used artic silver thermal paste just to be on the safe side. The heatsinking barely gets warm now. Iīm testing using a 200W 8ohm 12" speaker and a 60W 4ohm 8", both present the same problem. I substituted the C2 and C1 caps from ceramic to polyester and no change, the problem persists. Iīve tried with another split 18V PSU (1A this time) and still the same problem. The sound will not distort at low volumes but even at medium bedroom levels, the damn things start distorting. Although I know at 18V split I wonīt get maximum power, even at 5W volume (roughly) The distortion starts. I followed the schematic to the letter, 0.5mm indutor wire at the 10ohm resistor and all. All the circuits were hand soldered each in a singular way so Iīm out of ideas. I appolgize for the long post but Iīd really appreciate some help here. Thanks for your help, Daniel |
#2 |
the delay could be temperature related and may also be oscillation causing that temperature increase. 5W average power from a 30W amplifier is a lot. Most of the peaks will be clipped if you are using normal dynamic range music sourceS. Highly compressed CD & MP3 may not sound as badly clipped. It is normal to use an average power level of 1% of maximum to avoid most of the extreme peaks getting clipped.
regards Andrew T. |
#3 |
Thanks for the feedback AndrewT... Iīm dissapointed because I get more power out of the TDA2050 than the 3886 with the same power supply. I used MP3īs to test the output by the way.
Any tips on how to handle possible oscillations ? Thanks again, Daniel |
#4 |
18v +- is the lowest voltage that chip supports (according to the datasheet)
up the voltage and you should be right, because as most people know, an amp running below spec. voltage is going to distort very easily haydn |
#5 | |
Not to be confused with a +/- 18v split rail supply, which would be 36v from rail to rail. OP: Do you have a scope, or can you borrow one from friend / family? That would be a good way to check for oscillation. Otherwise you could try the light bulb trick (A simple 50W light bulb in series with the mains live, before the transformer) to see if the amplifier is consuming more power than is considered normal whilst idling. When switching on the light bulb should flash brightly for a couple of seconds and then fade dim or possibly not lit at all. If it stays lit up brightly it could be oscillation. |
#6 |
ah i didnt realise that... then it probably is oscilation then
regards haydn |
#7 |
Thanks for the replys guys!
The problem is solved, After giving up on the 3886, I tried the 1875 where I encountered very similar troubles. Thereīs a long post at dyistompboxes where the problem was solved.... turns out my transformer ground not hooked up to the circuit.The TDA2050 didnīt present this problem and R.G explained as to why. |
#8 | |
#9 |
interesting problem... oh well glad you fixed it
![]() regards haydn |
| Amp. troubles PLZ HELP!!!! | ReverB | Car Audio | 5 | 1st November 2009 01:11 AM |
| Chu Moy Headphone amp troubles | TheSeekerr | Headphone Systems | 21 | 29th August 2008 04:42 PM |
| SW troubles... PIA | nunayafb | Multi-Way | 7 | 30th March 2006 12:04 PM |
| ZV5 Startup Troubles | keenlyside | Pass Labs | 0 | 13th June 2005 06:35 AM |
| amp troubles | squid6 | Tubes / Valves | 5 | 8th July 2004 06:50 AM |
| Page generated in 0.10993 seconds (81.14% PHP - 18.86% MySQL) with 10 queries |
