Finishing up chipamp! - Page 13 - diyAudio
Old 6th November 2007, 01:42 AM   #121
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
Originally posted by anatech
Hi Dougie085,
Three wire mic cord is perfect. You know, for XLR connectors. Use one wire for ground, the other is hot and the shield is just a drain, grounded at one end only. If your grounding system is different, then do not use the second conductor as a ground.
Teflon anything is a pain to work with.
-Chris
Its actually not that bad, if you know how to use it and have Sharp Cutters.
Teflon wire is really good in the Class A amplifier because it won't melt.
Old 6th November 2007, 01:43 AM   #122
Magura is offline Magura  Denmark
Magura's Avatar
-Chris
Ohh, you tried that too at BAF07?
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 6th November 2007, 01:43 AM   #123
anatech is offline anatech  Canada
anatech's Avatar
Hi Magura,
It is not nice to work with (I belive I had the "pleasure" of working with this exact type at BAF07), and when I say not nice I really mean it, nasty stuff!
That's for sure. Once it's in, it will survive almost anything though!
Go buy a pair of el-cheapo earphones, salvage the wire and chuck out the rest.
Watch the wire in those be that cotton / tinsel stuff that is impossible to solder to. Not shielded either.
-Chris
"Just because you can, doesn't mean you should" my Wife
Old 6th November 2007, 01:44 AM   #124
anatech's Avatar
Hi Jason,
If stuff is that hot, you do not have to worry about the wire. Trust me on that!
-Chris
Old 6th November 2007, 01:46 AM   #125
Magura's Avatar
-Chris
It used to be just like microphone cable, just thinner,
Or is my memory playing tricks on me here?
Magura?
Old 6th November 2007, 01:50 AM   #126
anatech's Avatar
Hi Magura?,
I have seen those headphones made both ways. I don't count on anything any more. The ones that were made from shielded wire had such a loose <oxidized> copper wrap that it was next to useless as a shield. We are talking about 50% coverage or less.
At least the balanced mic cable is a sure thing, and not really expensive either.
-Chris
Old 6th November 2007, 02:24 AM   #127
I've never seen cheap headphones with shielded cable.
Old 6th November 2007, 02:37 AM   #128
Banned
they all have shielded cable, positive in the center and neg wrapped around the out side.
Old 6th November 2007, 11:00 AM   #129
pinkmouse's Avatar
If you don't want to go out shopping, and all your cheap headphones have unsuitable wire, why not just chop up a cheap phono-phono lead, the kind you get given when you buy a cheap hifi or DVD players?
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 6th November 2007, 08:21 PM   #130
Well I used some decent quality RCA cables I had and cut them up (it's what I had extra) The shielding on it is this plastic covered stuff it seems. Anyways I used it and when nothing is connected they are silent. Soon as I connect something though they get noisy. So seems like the RCA cable it self is picking up a lot. So I switched to a thicker shielded RCA cable and seems to help A LOT. Still a tiny bit of static though. But so much better.
An other finishing fung Multi-Way 16 10th April 2006 04:12 AM
Paint finishing?????? bostonswoop Everything Else 19 3rd February 2006 02:42 AM
Question about finishing sub box derekwwww Subwoofers 5 26th January 2005 10:48 AM
Finishing MDF Vivek Multi-Way 4 11th April 2002 04:23 PM
Copyright 1999-2017 diyAudio
