Finishing up chipamp!
Old 6th November 2007, 08:29 PM   #131
anatech is offline anatech  Canada
anatech's Avatar
Hi Dougie085,
Try changing where the cable runs (move it around). You may find a quiet route.
-Chris
"Just because you can, doesn't mean you should" my Wife
Old 6th November 2007, 08:39 PM   #132
Dougie085 is offline Dougie085  United States
I think I'm going to build a nice shielded interconnect. I have this hooked up to my computer at the momment. Planning on getting a USB dac to go with it and probably build a shielded interconnect to use with it. Should eliminate a lot of the sound as I'm pretty sure a bit is coming from the cheap computer sound card.
Old 6th November 2007, 09:25 PM   #133
Nico Ras is offline Nico Ras  South Africa
Nico Ras's Avatar
Hi dougie, try disconnecting one input ground so that there is no external loop. This has solved many problems in the past.
Finishing up chipamp!Hide this!Advertise here!
An other finishing fung Multi-Way 16 10th April 2006 04:12 AM
Paint finishing?????? bostonswoop Everything Else 19 3rd February 2006 02:42 AM
Question about finishing sub box derekwwww Subwoofers 5 26th January 2005 10:48 AM
Finishing MDF Vivek Multi-Way 4 11th April 2002 04:23 PM
Copyright ©1999-2017 diyAudio
