Finishing up chipamp!
Old 6th November 2007, 01:21 AM   #111
defect9 is offline defect9  Ireland
defect9's Avatar
what gauge of wire are you running from the RCAs to the boards? also, are they shielded?
-Jared
Old 6th November 2007, 01:33 AM   #112
Dougie085 is offline Dougie085  United States
Well it was 18guage stranded wire. Now its 26ga single strand magnet wire. Not shielded.
Old 6th November 2007, 01:36 AM   #113
Magura is offline Magura  Denmark
Magura's Avatar
When having a mess of power wires like you got there ( no disrespect, I make the same mess or worse when prototyping), you may benefit from running shielded signal wires. Remember to only connect the shield in one end.
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 6th November 2007, 01:56 AM   #114
Think this stuff is good? http://cgi.ebay.com/50-22-AWG-Shield...QQcmdZViewItem
Old 6th November 2007, 02:19 AM   #115
Magura's Avatar
It's overkill
Go see any musicians shop and buy some micrphone cable or the like, or just salvage some from an old pair of headphones....
Magura
Old 6th November 2007, 02:29 AM   #116
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
Originally posted by Magura
It's overkill
Magura
That is what i told him to do, we have been talking on line for the last fwe months and he asked for some help, however Peter insisted that it is not necessary.
it would cost no more than 5$ for mic cable
The stuff that he has pointed out from ebay, is what i use in my pre-amp's and aleph's and it works good, i even use it for other things like cables and speaker wire, best stuff i have yet.
Jase
Old 6th November 2007, 02:33 AM   #117
I tried to find Mic cable noone has it. The only mic cable I can find is about the price of that stuff so I'd rather just get that stuff. And since when is overkill bad???
Old 6th November 2007, 02:37 AM   #118
Banned
Well, like i said if you buy 50 feet ot it u can use it with other project's and for speaker wire
Old 6th November 2007, 02:39 AM   #119
anatech is offline anatech  Canada
anatech's Avatar
Hi Dougie085,
Three wire mic cord is perfect. You know, for XLR connectors. Use one wire for ground, the other is hot and the shield is just a drain, grounded at one end only. If your grounding system is different, then do not use the second conductor as a ground.
Teflon anything is a pain to work with.
-Chris
"Just because you can, doesn't mean you should" my Wife
Old 6th November 2007, 02:40 AM   #120
Magura's Avatar
Well, since overkill included the words teflon and wire in the same sentence. It is not nice to work with (I belive I had the "pleasure" of working with this exact type at BAF07), and when I say not nice I really mean it, nasty stuff!
Go buy a pair of el-cheapo earphones, salvage the wire and chuck out the rest.
Magura
Finishing up chipamp!Hide this!Advertise here!
An other finishing fung Multi-Way 16 10th April 2006 05:12 AM
Paint finishing?????? bostonswoop Everything Else 19 3rd February 2006 03:42 AM
Question about finishing sub box derekwwww Subwoofers 5 26th January 2005 11:48 AM
Finishing MDF Vivek Multi-Way 4 11th April 2002 05:23 PM
Copyright ©1999-2017 diyAudio
