| Chip Amps Amplifiers based on integrated circuits |
I want input clipping protection system. But I doubt as the input capacitor acts like clipping protector as it will not allow DC into the circuit....but does it work? or do i need to have a circuit for it? please guide me...
thanks, Ken |
#2 |
No, sorry a cap won't do the job. You need a circuit. I know of a simple one if you have +/- voltages available , but I won't be able to post it till later.
#3 |
another way is to set your input sensitivity to about 600mV an use a diode over the input to limit the input voltage.
#4 |
A diode will create clipping becase it will chop off the tops and square it resulting in severe distortion.
Using a diodes to clip or limit the siganl in FMamplifiers is more apropriate because you need frequency information and amplitude information is not important so noise is clipped. |
#5 |
If you're worried about a DC offset at the input of the amp propagating to the output, a capacitor will do the job (assuming the DC is coming from the source, not the amp).
If you're worried about clipping in the more conventional sense- i.e. the amp slamming to one rail or the other due or both due to an input overload, you probably don't want to use diodes. Diodes will clip the signal and cause the same sort of distortion you're trying to avoid. Try this page: http://sound.westhost.com/project67.htm or this: http://graffiti.virgin.net/ljmayes.mal/comp/comp.htm I_F |
| Input Capacitor | otherside | Chip Amps | 26 | 20th January 2010 03:32 PM |
| Input capacitor | Triox | Solid State | 31 | 20th January 2010 09:28 AM |
| 5u4g input capacitor | alexg | Tubes / Valves | 4 | 4th June 2009 05:33 AM |
| Input Capacitor | Shaz | Chip Amps | 3 | 20th September 2003 06:39 PM |
| P3A Amp: Input Capacitor C1 | dine1967 | Solid State | 4 | 3rd February 2003 12:46 AM |
| Page generated in 0.07666 seconds (76.55% PHP - 23.45% MySQL) with 10 queries |
