In Bridged mode there shouldn"t be any stability problems as long as you are useing a Low enough Voltage.....With an 8 Ohm speaker in Bridged mode each Chip is driveing a 4 ohm load so the Supply Voltage should be kept under +/-30v and a Big heatsink will also be good.....
I am building a Bass amp useing 2 LM3886 in Bridged mode with an Opamp inverter and a Huge heatsink running off of +/-26v rails and I am powering a 12 in Sub and a 10in Driver, I am also useing a 15 Band EQ I scavenged from a Busted Rane EQ for the Tone controlls....It is still a work in progress.....
Cheers
Cheers
