| Chip Amps Amplifiers based on integrated circuits |
Ive been planning to drive Vifa PL26W 8ohm woofers with chip amplifiers. But I wan to cutdown the complexity of the amp but I still need good quality sound for recording studio. Ive been checking over the net and I found that NORH subwoofer uses TDA 7294 chip single to drive the subwoofer. The PL26W is just the next size of the driver used in NORH sub..
http://www.madisound.com/catalog/pro...oducts_id=1142 the one that I want to use is http://www.madisound.com/catalog/pro...oducts_id=1144 just the next size of the same category woofer but with almost same specs... so my question is TDA and LM3886 chip amps has got similar of 70 watts RMS into 8 ohms so if the TDA chip can drive the woofer efficiently then do two of the LM3886 chips can be sufficient enough to drive the 10 inch woofer? I mean can it go till 125 watts? or shall I stick on to the TDA? Ive been fiddling with the thought and I was thinking of going with the BPA 200 to drive the chip but it will become way too complicated in almost every aspect.. like trafo, heatsink, DRV circuits etc etc etc... so friends tell me what makes it to drive the woofer better...? 2 LM3886 chips in parallel? 2 LM3886 chips in bridged?( one chip for positive cycle and vicevarsa) 4 chips in parallel? 4 chips in BPA200 mode? 1 TDA 7294 chip? 2 TDA 7294 chips in parallel? 2 TDA 7294 chips in bridged? please friends help me.... But I want ultimate quality since im using premium woofers... thanks, Ken |
#2 |
I think that even one LM3886 or TDA7294 would be ok for powering your Vifa driver due to it's very limited Xmax. You don't really need 125 W just because your driver can take it thermally. Simulate the driver in the box you are planning to use using some program like WinIsd, apply some power and watch for excursion. My last sub had inexpensive 12" Westra driver in it and I powered it with only one TDA 7293 (newer version of TDA7294), and it very easily bottomed out.
I made a lot of amps based on LM3886 and TDA7293 and found that it is much easier to make the PCB's for LM's because of their much simpler pinout, so for simplicity you could go that way. If you eventually decide that one chip doesn't have enough power for your needs, bridging would be the way to go because Vifa is 8ohm driver. At the moment I use 2 LM's bridged to power 12" Peerless driver with 3x displacement of yours and 90% of time I find them enough strong for the job. LM's and TDA's sound much different, so it is also a matter of music taste when choosing a chip. Hope this helps ! |
#3 |
Ken
before you get too deep into amp choices , if you haven't already, toss the speaker params into WinISD Pro ( free BTW ) . Look at cone excursion for your desired power . I see the spec on this woofer is 4mm Xmax . I just put together a dissapointing 8in Sub . ( 6mm xmax ) I didn't note xmax limited power of 25W at 30HZ this speaker was "rated" at 80W ...arrrgh . Wayne |
#4 | |
yeah I ve checked with the WINISD alpha program and its true it shows max excursion at 50watts even though its rated at 125RMS...
how long you have been using the LM3886 chips to drive those massive babies? are you getting chest pounding bass with these two LM chips in Bridged mode? whats ur power supply trafo and caps? did u use toroidal? thanks, Ken |
#5 |
Ive been searching all over the net to find the X max for the PL26W driver but I couldnt find it ... even on the tymphany website... how did u get this info?
#6 | |||||
If you provide adequate heatsinking you can go few volts above what's stated in the datasheet to extract few watts more, especially with TDA. Quote:
Something like this: http://sound.westhost.com/projects-9.htm Chips are never getting too hot, but when I push the limit too far, the SPIKE protection kicks in on music peaks. I've been using this configuration for 8 months now, I plan to build something stronger soon, but I'm too lazy at the moment. Quote:
More info on the amps: 6 monoblocks finished |
#7 |
hello cromaniac can u please mention the 12 inch peerless subwoofer model no... is it XLS or XXLS etc.. which one specifically...?
but anyway thanks alot for the info... but im still struggling regarding bass tilt circuit can u help me how the cricuit will be? pls.... thanks, Ken |
#8 |
It is 12" XXLS model 830844 with 12" passive radiator model 830844.
You can see the pic of the sub in this thread: My XXLS Subwoofer building thread... I don't understand the term "bass tilt". Is that some kind of shelving filter ? |
#9 | |
how about the gain control circuit... like i want to control input gain using a opamp or so... in -1db to -6db.... I think you are an expert i got few links from other forum members but i need a clear circuit diagram to control it..if you know please guide me... thanks, Ken |
#10 |
rhythmdiy, if you only want to adjust the gain to match the sensitivity of the midrange driver, try this:
http://linkwitzlab.com/filters.htm Look at the paragraph 10 - Variable gain. That's what I am using in preamp to adjust sensitivity between midbass and tweeter. If you decide to use circuit A, note that it inverts the signal, so take that into account when designing your bass preamp/crossover circuit. |
| Audiophile quality PA at below cost 18" woofer 1500 Watts of AMPS | LuminousMaximus | Vendor's Bazaar | 1 | 31st March 2009 11:17 PM |
| Amp on TDA 7294 | maris24 | Chip Amps | 4 | 17th November 2006 10:11 AM |
| TDA 7294 Use it or go LM3886 | benje | Chip Amps | 6 | 8th January 2005 07:45 PM |
| TDA 7294 PCB - need help :) please | Szaflik | Chip Amps | 3 | 17th December 2004 08:51 AM |
| Page generated in 0.12969 seconds (83.75% PHP - 16.25% MySQL) with 10 queries |
