| Chip Amps Amplifiers based on integrated circuits |
Hi there. I have a Marantz PM-57 amplifier which stopped working whilst being run fairly hard. I have diagnosed a faulty mains transformer and am trying to source a replacement. I am having a hard time locating a spare. Does anyone have any suggestions where I can get my hands on one or a schematic so I can work out what voltages are required or failling this can tell me what output voltages the original transformer gave to replace it? Is there any advantage to me fitting a toroidal transformer instead?
If you could help me out at all I'd be eternally grateful. Regards, |
#2 |
Are you absolutely certain that it is the mains transformer and not a bad connection somewhere? If you have crimped terminals on the mains lead to the power switch etc, try cutting them off and replacing them with new ones.
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#3 |
Hi there. Thanks for your reply. Yes I tested the output of the transformer and it is giving nothing. I am guessing it has overheat protection (thermal fuse of some sorts) which has blown.
#4 | |
#5 |
The boards in these amps are the same as the ones in the later PM66/PM6010.
The transistors are different and some components are also different. But given the huge gains experienced by changing the tx in those amps, I would find the largest va that you can. I cannot remember what voltage they are, but if you find the pm66 mod thread and ask there, I'm sure someone else could tell you. cheers, Lee.
| Marantz 510M Power Amplifier | pkgum | Solid State | 3 | 16th February 2009 08:02 PM |
| Marantz PM4400 Amplifier | seanww69 | Solid State | 11 | 3rd September 2007 05:11 PM |
| Marantz PM6010 ose Amplifier | TexMex | Solid State | 4 | 20th August 2006 08:13 AM |
| fs Marantz amplifier | maliburon | Swap Meet | 1 | 28th June 2006 06:08 PM |
| OP-AMPS in Marantz PM7000 Amplifier | Alex2 | Chip Amps | 0 | 17th February 2004 08:17 AM |
| Page generated in 0.07394 seconds (73.41% PHP - 26.59% MySQL) with 10 queries |
