| Chip Amps Amplifiers based on integrated circuits |
Hi when I put my head very close to the chassis, I can hear the transformer working it is a Gainclone LM3875.the transformer is Plitron #200734 300va 22 x 2 120ac.and the rectifier is a single board,(8 diodes total four for each channel)is this normal?
should I get a better transformer (Quieter)?. this is the only thing that I am worried about.I do not hear nothing from speaker(noise) it is jut from transformer. thank you. |
#2 |
Electrons are yellow and more is better!
A transformer does hum, some more, some less. If it's not annoying I can't see the problem.
/Per-Anders (my first name) or P-A as my friends call me Tube Buffered Gainclone in work |Thread |
#3 |
If it bothers you, you can try mounting the transformer on a foam pad and put another one on top between the trafo and the metal disk that clamps it down. That may help.
--Sherman |
#4 |
Thank you guys for suggestions.and as you said "peranders" it is not so bad at all.the noise is when I put my ears on top of transformer.so I will leave it like it is.and beside the two channels are noise free.I do not hear any noise except clear music.thank you guys.
| How quiet is dead quiet? | pchw | Tubes / Valves | 36 | 22nd November 2007 04:36 AM |
| My first ESL: works but VERY quiet | bigwill | Planars & Exotics | 69 | 6th July 2007 07:52 AM |
| Quiet here, isn't it? | pinkmouse | The Lounge | 24 | 8th February 2005 08:29 PM |
| How quiet will it be? | MMicke | Chip Amps | 8 | 12th July 2003 08:26 PM |
| Too quiet! | grataku | Everything Else | 14 | 14th February 2003 04:39 PM |
