Old 22nd October 2007, 01:38 PM   #1
Paswa is offline Paswa  India
Paswa's Avatar
Default What means by decouple
In datasheet of TDA2050, they said to properly decoupl INPUT1 and INPUT2 from ground.
CAN You explain "DECOUPLE" and how to do this.....I'm a newbie..,he!he!
Old 22nd October 2007, 01:44 PM   #2
Electrons are yellow and more is better!
peranders's Avatar
In this case, don't mix power ground with signal ground. Don't let currents in the ground coming from the speaker mix with the input ground. Take a look at the pcb layout in the datasheet. Do you see how the ground from the input meets the power ground?
/Per-Anders (my first name) or P-A as my friends call me
Old 22nd October 2007, 02:08 PM   #3
marce is offline marce  United Kingdom
Reading the thompson data sheet and having a look at thier layout, i would agree with Peranders, that it is actualy star grounding and not realy decoupling in the real sense, that Thompson are on about, it is a confusing use of terminology IMO.
Decoupling is when capacitors are used to electricaly isolate a pin from a ground (or two grounds from each other, not so much used these days) for generaly two reasons, one to provide a low impedance path for any noise at the pin, and in the case of supply pins to provide the instantaneous current required during fast switching (or large bass transients) for the small amout of time it takes the PSU to deliver the power itself.
To decouple or not to decouple. Colescuttle Chip Amps 6 15th September 2006 10:35 AM
How (Not) to Decouple High-Speed Operational Amplifiers Ruach Digital Source 24 17th October 2005 01:50 AM
DG271 as means to decouple output. Calimero Digital Source 3 11th March 2005 03:00 PM
To decouple or not.Counter weights sleepy Analogue Source 8 13th April 2004 01:47 PM
Input stages - to decouple B+ or not? andyjevans Tubes / Valves 1 9th March 2004 10:28 AM
Page generated in 0.08826 seconds (76.97% PHP - 23.03% MySQL) with 10 queries
